Old 06-10-2011, 04:53 PM   #1
son of 19
son of 19's Avatar
Default what about this"
I have my A running great. except thr gav when I turn it 1/4 turn it starts to turn by it self and keeps on turning tell it get where it want to be. and then it is not running good how do I stop this? I have to hold it in a 1/4 turn and that is hard to do and change gears. thanks son of 19
son of 19 is offline   Reply With Quote
Old 06-10-2011, 05:01 PM   #2
1930artdeco
1930artdeco's Avatar
Default Re: what about this"
Maybe put a larger grommet or something around the choke rod to keep from vibrating open.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 06-10-2011, 05:06 PM   #3
son of 19
son of 19's Avatar
Hi" thanks I have the same ford town sedan briggs. son of 19
Old 06-10-2011, 05:56 PM   #4
Colorado Greg
Colorado Greg's Avatar
There is a spring clip around the end of the GAV housing. When the needle is screwed into the housing, the spring clip keeps tension on the needle to prevent it from turning. Your's might be missing or loose, you might be able to take it off, compress it a little and reinstall. There should be some tension on the needle. Make sure the housing is tight in the carb as well.
"Betsy doesn't leak oil - she just marks her spot"
Colorado Greg is offline   Reply With Quote
