Old 02-23-2014, 03:47 PM   #1
RMR&C
RMR&C's Avatar
Default Can I use these lifters?
I'm beginning a rebuild on my 8ba type V8. I picked up these NOS lifters a few years ago and may want to use them. I believe they are for earlier V8's. Dimensions appear to be the same....
Aside from how they look, are there any differences?
RMR&C is offline   Reply With Quote
Old 02-23-2014, 04:07 PM   #2
Pete
Pete's Avatar
Default Re: Can I use these lifters?
Those are stock cast iron lifters.
They are ok for a stock engine.
You should use the hollow steel ones for a performance engine.
They can be recognized by having ONLY two 5/32 holes in the side.
If you use the ones you have, be sure there are no rust pits or corrosion
on the face.
Old 02-23-2014, 04:11 PM   #3
Iron Mike
Those lifters are for the early mushroom tip valves used with split guides; I've never used them with 49-53 valves upon the advice of others. There is concern of the smaller contact area of the late valves accelerating wear or punching through the early lifters. I have disassembled engines that had mismatched components and there was a definite recess of the contact point on the top of the early lifter. Spring pressures, r.p.m. and valve float all enter into the equation but I'd recommend matching the lifters to the valves........I.M.
Iron Mike is offline   Reply With Quote
Old 02-23-2014, 04:17 PM   #4
Iron Mike
Your right Pete, those are cast iron not hollow; my advice is for hollow non scalloped lifters...... eyesight is not so good anymore.... the weight of those would be my only concern......I.M.
Old 02-23-2014, 05:42 PM   #5
flatjack9
flatjack9's Avatar
They are hollow.
Old 02-23-2014, 07:12 PM   #6
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Yes they are hollow, as Pete says, there early cast iron, They quite using them I think in the late 30's and went to the steel ones, I've seen a few of them broken. There 1-720 length same up to 50 Ford. Yours are new and should work ok on a stock engine with stock valve spring pressure, That's about 42# seat pressure. I wouldn't use them in a performance engine. Walt
Old 02-23-2014, 08:21 PM   #7
RMR&C
RMR&C's Avatar
Thanks for the replies!...yes it is a stock rebuild. The engine had the hollow steel ones, but they are very worn where they contact the valves.
