Old 09-11-2015, 11:48 PM   #1
willowbilly3
Default question on master cylinder.
I mounted a 62 era Galaxy master cylinder to a 7 inch dual diaphragm booster on an of topic car. (Ok to replace the treadle-vac on my 56 caddy). Final went to move the car and the pedal was rock hard. I have good vacuum. I pulled the m/c and the booster moves ok. Pulled the m/c and it pumped fine. Re-installed it and tried it with the line off (engine running) and everything seemed ok, had boost and pumped out fluid. No blockage in system, all new and gravity bled fine.
Now the question is, does it matter which port you plumb the brakes to? I used the top one where the brake light switch would normally go.
willowbilly3 is offline   Reply With Quote
Old 09-12-2015, 12:53 AM   #2
rich b
rich b's Avatar
Default Re: question on master cylinder.
If you are using the Treadle-Vac pedal assy, you probably do not have enough mechanical advantage to push a regular booster and master.
rich b is offline   Reply With Quote
Old 09-12-2015, 09:17 AM   #3
Motorhead6
I assume that is a single line M/C. In that case it does not matter which port you use as I believe they intersect to the main line of fluid flow anyway.
Motorhead6 is offline   Reply With Quote
Old 09-12-2015, 09:32 PM   #4
willowbilly3
That's what I thought.
And I'll have to check the pedal ratio on the bell crank, never thought of that.
Old 09-12-2015, 10:11 PM   #5
willowbilly3
I just took a flashlight and had a look. I think rich nailed it. Looks like barely 2:1 pedal ratio. I'll have to rework some of the pivot points from the pedal to the bell crank.
Old 09-14-2015, 10:29 PM   #6
tdlmomowers
tdlmomowers's Avatar
Make sure that you have some free play in the master cylinder rod.
tdlmomowers is offline   Reply With Quote
Old 09-15-2015, 05:36 AM   #7
willowbilly3
The master cyl really doesn't have a rod, just bolts right on the booster. Maybe some small adjustment on the stub coming out of the booster.
And thanks for helping me on my non ford, 2 caddy forums and nobody knew there was no pedal ratio??
