Old 05-15-2015, 09:00 AM   #1
Big_Guys_baby
Default What is acceptable oil pressure at operating temp
Hey gang,
I have been doing a bunch of searching but cannot seem to find a clean thread discussing operating temp oil pressure. I am curious what is acceptable idle and cruising speed Oil pressure would be, or at least what figures you guys are running?
Big_Guys_baby is offline   Reply With Quote
Old 05-15-2015, 09:04 AM   #2
Big_Guys_baby
Default Re: What is acceptable oil pressure at operating temp
Whoops! Meant to post in Early V8 Forum! Sorry
Old 05-15-2015, 12:19 PM   #3
Ricks56
Not sure what is acceptable but my 312 runs about 65 lbs at road speed and drops down to 30 lbs at idle when hot.
Ricks56 is offline   Reply With Quote
Old 05-16-2015, 06:12 PM   #4
cjc56
It is not unusual for oil pressure to be 20psi when hot and at idle. I have seen newly rebuilds that run 20 when hot at idle. Especially if you have done a good job of cleaning all the oil galley channels. I have a 304 in a 70s vechile that runs around 15 when hot at idle, but step on the gas and it goes to 30-40. Never had a problem with the engine.
cjc56 is offline   Reply With Quote
Old 05-17-2015, 09:08 PM   #5
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
I agree with Ricks56. 65# at speed and 30-35 at hot idle is what I like to see in any fresh YBlock I do.
streetdreams is offline   Reply With Quote
Old 05-18-2015, 04:02 PM   #6
tdlmomowers
tdlmomowers's Avatar
I was always told that most modern engines only require 10 psi per 1000 rpm.
tdlmomowers is offline   Reply With Quote
Old 05-18-2015, 04:07 PM   #7
billwill
What engine are referring of .
billwill is offline   Reply With Quote
Old 05-18-2015, 08:20 PM   #8
Diavolo
Diavolo's Avatar
This. If the engine is under normal operating conditions, this is it. Modern engine or not, it doesn't matter. Any more is, at best, scavenging power and any less is indicative or loose tolerances or a need for thicker oil.
Diavolo is offline   Reply With Quote
Old 05-19-2015, 04:18 PM   #9
cjc56
His question was "what is acceptable". I take that to be, what is be what is the lowest psi before the engine get starved for oil. 15-20 at hot idle would still get oil to all parts of the engine. I agree a new rebuild should be more unless you have modified the oil galleys which could reduce pressure but increase flow.
Old 05-19-2015, 06:59 PM   #10
54vicky
54vicky's Avatar
I agree with Rick and Street that is what all mine have when new then sometime (years) later be it shrub or my Ys
54vicky is offline   Reply With Quote
Old 05-20-2015, 05:01 PM   #11
ems customer service
type of oil changes things a lot, i will use 10-40 or 20-50 to up the pressure if i am doing a hot slow speed cruise, i have seen 5-10 psi at idle on a hot 85+ day
ems customer service is offline   Reply With Quote
