Old 10-01-2015, 10:07 AM   #1
katy
katy's Avatar
Default Question about Loctite
What's the difference between red and blue Loctite? Other than the colour that is.
I tried a web search and all I came up with was numbers, no colours.
Old 10-01-2015, 10:14 AM   #2
1932BB
Default Re: Question about Loctite
Red is higher strength than blue but may require heat to loosen.
1932BB is offline   Reply With Quote
Old 10-01-2015, 10:26 AM   #3
Mitch//pa
you forgot about purple and green
http://us.henkel-adhesives-blog.com/...Threadlockers/
Old 10-01-2015, 10:34 AM   #4
V4F
V4F's Avatar
stay away from purple & green as they are "stud tight" . not user friendly . I use both red / blue with good results .
V4f
V4F is offline   Reply With Quote
Old 10-01-2015, 10:50 AM   #5
Mitch//pa
i use the green on carrier bearings
Old 10-01-2015, 11:00 AM   #6
katy
katy's Avatar
Thanks guys, much appreciated, Ken
Old 10-01-2015, 06:54 PM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Use PURPLE LOCTITE for lipstick & enjoy a LOOOOOOONG KISS
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-01-2015, 07:02 PM   #8
SeaSlugs
SeaSlugs's Avatar
I did too on my AA worm drive. At work we have it on large spindle bearings and machining center rams, if you want that bearing or race to stay put use green. If you ever want to remove it better get a cutting torch to get it red hot....
blue is removable by hand tools, red you better get an impact, green and purple better get a cutting torch...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 10-01-2015, 07:31 PM   #9
C26Pinelake
I agree with you totally! Great advice. Wayne
C26Pinelake is offline   Reply With Quote
Old 10-02-2015, 04:19 PM   #10
BILL WILLIAMSON
I use a drop of Blue Loctite on lots of things, helps the car from getting LOOSEY-GOOSEY, from vibrations.
Bill W.
Old 10-02-2015, 04:42 PM   #11
harleytoprock
Purple is low strength, suitable for small screws. There are a bunch of different greens. One is wicking, you add a drop to already assembled fasteners. The other greens are for press together things like bearings and shafts. The red is high strength, is available in regular or high temp and require heat to disassemble. Blue is med strength and comes apart easily.
harleytoprock is offline   Reply With Quote
