10-22-2014, 02:00 PM | #1 |
Hoist Question
To remove the engine I am going to need a hoist. Is there anything special I should know about? I was thinking of purchasing the following, but don't want to get it all set up and not have clearance or have issues with the lift. Thoughts?
http://www.harborfreight.com/1-ton-c...ane-69512.html |
10-22-2014, 02:05 PM | #2 |
Re: Hoist Question
There is no particular reason that will not work. Some members will not recommend the Harbor Freight product. For occasional use it will be fine. You will need either 1 or 2 eyelets that are sold through the national vendors or a plate to bolt on top of the motor as an aid to hoisting the motor out of the car.
10-22-2014, 02:08 PM | #3 |
Re: Hoist Question
Seth that cherry picker will work fine for you. one of the few things i own from harbor freight is that. i just use the eye hook in #3 plug hole to lift it out simple and easy
no rocket science needed |
10-22-2014, 02:08 PM | #4 |
Re: Hoist Question
I have the two ton version of this shop crane and recently removed the engine from my A with no problems. I ran a short piece of chain between two eyelets screwed into the cylinder head and attached the crane hook to the chain.
10-22-2014, 02:10 PM | #5 |
Re: Hoist Question
I figure that the hoist will be used for removal and re-installation by me once. I can't see me using it much after doing this work but will add it to the local club's "available tools" list. If there are alternative hoists on the market, I would consider them as well.
10-22-2014, 02:14 PM | #6 |
Re: Hoist Question
here is the eye hook off brattons FYI or you can do it 50 other ways chain, seatbelt etc |
10-22-2014, 02:19 PM | #7 |
Re: Hoist Question
I have had that very lift for over 10 years and have punished it severely yet it has yet to fail me. (I have suspended complete rolling chassis, without drivetrain, off the ground for sandblasting, with a 15 foot extension stuck in the end.... do not attempt this at home...i'm an professional idiot )
This is built well enough to stand a lot of use. Remember to take you discount coupon with you. |
10-22-2014, 02:21 PM | #8 | |
Re: Hoist Question
10-22-2014, 03:01 PM | #9 | |
Re: Hoist Question
10-22-2014, 03:22 PM | #10 |
Re: Hoist Question
I bought this same unit but in the 2 ton capacity and it is great. I also have used it for body removal off of my roadster. When it is not in use the legs fold up and it is just pushed in the corner where it takes very little room.
10-22-2014, 03:22 PM | #11 |
Re: Hoist Question
I have the same cherry picker. I pulled my engine and transmission this morning. It worked flawlessly.
Occasionally HF has a coupon for this lift for $99. Ask around, you might get lucky and find one. Good luck with your project, Dan |
10-22-2014, 03:24 PM | #12 |
Re: Hoist Question
1 ton is more than adequate for Model A work, and a folding crane makes storage easier. I can't find a rental shop that will offer one here any more. They all claim they come back damaged because guys misuse them. I'd say buy it; you'll be surprised how often you can use it.
10-22-2014, 03:35 PM | #13 |
Re: Hoist Question
I have the same hoist and like the others had no problem installing the engine along with bell housing and transmission HOWEVER when putting it on or off the engine stand it is a little awkward although doable (sp?). The engine stand is a HB product also.
10-22-2014, 03:49 PM | #14 | |
Re: Hoist Question
10-22-2014, 04:02 PM | #15 |
Re: Hoist Question
My Grandson likes it...
10-22-2014, 04:04 PM | #16 |
Re: Hoist Question
I've been going thru the process of deciding whether or not to get one of these. The biggest problem is that of adequate storage when it's not in use, but I think I can live with that. I probably wouldn't mind the HF unit; price is right, but the freight would kill me. Soooooo, I've been looking at Amazon (prime=free shipping) or Craigs list locally = no freight. Having it when I need it and not having to beg/borrow is my greatest push. I've already had to do that twice, and could again if I have to.
I just like having my own tools! Isn't that what owning a Model A is all about?? An excuse to buy more tools.
10-22-2014, 04:04 PM | #17 |
Re: Hoist Question
For the record, I have a 20 year old HF floor drill press and a floor band saw, both work fine...
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
10-22-2014, 04:11 PM | #18 |
Re: Hoist Question
To all... thank you for the inputs. I've decided to go with this model.
Dan... you inspired me to look for a coupon. I found a HF 20% off one that didn't work online when I tried to use it. This was a good thing. I called HF to have them figure out why. We resolved the issue and it worked. Goofing around with the woman on the phone, I asked if there were any "better coupons". She found one. I was able to get the hoist for $99. With delivery and taxes it came to $115. Dan, I owe you a beer. |
10-22-2014, 04:12 PM | #19 |
Re: Hoist Question
Carl G, give HF a call. The shipping on mine was almost nothing. I don't know if that $6.99 standard shipping applies to Alaska, but you might as well ask.
10-22-2014, 05:18 PM | #20 | |
Re: Hoist Question
Your right, I'm the same way about having my own tools. Learned a long time ago when I was a Motorcycle Mechanic not to lend or borrow tools... I must admit owning an "A" kind of forces you to buy some "A" specific tools but it is really is an excuse to buy more tools. "But Honey, I can't change my Stop Light Fluid without this special wrench". |
