02-01-2015, 02:51 PM | #1 |
How much evaporation from gas tank is normal?
Hi,
My model A has been resting in my uninsulated garage during the later part of the summer. Temperatures reached 80 degrees on some days inside. The tank was filled approx. oke quarter with a closed lid. I always noticed the gasoline smell when I went into the garage. Now, this afternoon I checked the tank and it was bone dry. Is it normal that so much gas can evaporate by itself? Lucas |
02-01-2015, 03:59 PM | #2 |
Re: How much evaporation from gas tank is normal?
it is my opinion it is not normal and you likely have a leak problem and not an evaporation problem. Start at the obvious problem areas and go from there. I would check the tank first and then the shut off valve or ice versa. Let us know. Wayne
02-01-2015, 05:07 PM | #3 | |
BTW...should have advised that any gas leak is bad, BUT there is a silver lining to be seen here...if the leak is not a crack in the tank ! Take this as a good time to clean 'empty' tank, if indicated as necessary. Take the few connections/lines off and ensure that the 'in tank' pencil pre filter is there or put one in. Make all connections leak proof and be happy that you do not have to DRAIN the tank at this time to accomplish all this ! Good luck Last edited by hardtimes; 02-02-2015 at 01:41 PM. Reason: .......... |
02-01-2015, 05:34 PM | #4 |
Uh, like Wayne sez: not normal to smell what little gas might evaporate from the tank.
Leaks can sometimes be pretty subtle and hard to detect. Check shut-off valve inside cabin, sediment bowl, fuel line connections at sediment bowl and carb. If you let the gas run out of the carb by allowing the engine to run after you've turned off the shut-off valve, you should have no leaks between there and the carb unless that valve is not working properly. Look for signs of a leaky valve: is it wet with gas? Are there stains on the floor? The sediment bowl may leak due to a faulty gasket or crack in the bowl itself. Check the fuel line at the junction with the sediment bowl and where the line connects with the carb. If you have engine pans, check the one under the carb for signs of dripping. Or check the garage floor under the carb. Mop the bottom of the carb with a paper towel. If it's wet, track down the source. If the leak is coming from the throat of the carb, it may be the float valve is not working or is not adjusted correctly, or the float is "water-logged". Check the fuel line connection where it enters the carb. |
02-01-2015, 11:54 PM | #5 | |
Add me to the no way, you have a leak list. Let's have some fun, approx 15,140 drips to a gallon (found this on line) approx 2.5 gal to a quarter tank 37,850 drips to empty the tank two months storage? 1440 hours a drip every 2 minutes = 43,200 drips So with a leak of a drip every 2+ minutes your tank will be empty in two months.
02-02-2015, 12:13 AM | #6 |
02-02-2015, 05:13 AM | #7 | |
As a qualified drip(per) I know water is about 0.05 cc per drop, and thinner liquids like petrol a bit less. So 2.5 gallons is about 189250 drips - give or take a few each way! Over 1440 hours to empty, this is 1 drip every 27 seconds. Still very feasible but a rather bigger fire hazard. Any other takers to dispute my expertise in dripping? Seriously, in my laboratory work, we often use drops to administer small quantities of liquids too small to weigh accurately. First we count how many drops in, say, 1 gram and proceed to add drips from there. I maintain a drip and a drop are the same size. Others may disagree. Or maybe my arithmetic is wrong? SAJ in NZ EDIT This just goes to show, people will argue about anything Last edited by SAJ; 02-02-2015 at 05:45 AM. Reason: more fun |
02-02-2015, 05:43 AM | #8 |
You have Serious Leak Good Luck
02-02-2015, 03:36 PM | #9 |
Thanks for all your answers.
Lucas |
02-02-2015, 04:59 PM | #10 |
Have you checked around the bracket under the fuel tank that holds the steering column? This is a frequent offender. I think the next most likely culprit is a leaky shut off valve.
02-03-2015, 12:18 AM | #11 | |
02-03-2015, 01:52 AM | #12 |
The size (mass) of a liquid drop is dependent on several factors:
1) The surface tension of the liquid. Water and gasoline are not equal! 2) The length (circumference) of the boundary between the hanging drop and the adhesion surface from which it hangs. Small tubes of varying diameters ("droppers") and planar surfaces will all produce different boundary lengths. 3) The adhesion constant between the liquid and substrate from which it hangs. Is the surface philic or phobic? 4) The angle of contact between the drop pendulum and the substrate. Is the drop hanging from a horizontal plane of contact or is the substrate at an angle? Taking the above all together the mass of the drop will equal the boundary length times the liquid surface tension constant times the sine of the droplet pendulum angle divided by the acceleration constant where the drop hangs (gravity = 9.8 M/sec-sec). In summary, I have no clue how big the drops are, nor does anyone else. Just fix the leak. |
02-03-2015, 05:46 AM | #13 |
You guys got it all wrong!
The neighbor kid snuck in and siphoned the tank dry to fill up his Rat Rod.
Dave / Lincoln Nebraska |
02-03-2015, 06:25 AM | #14 | |
Wayne |
02-04-2015, 03:37 AM | #15 |
Cripes! What did I get myself into? My post was meant as a joke too.Just like Mike K's scientific spoof that followed it.
The important thing is to fix a possibly bad leak or catch 1 Croscutt's siphoner. SAJ in NZ Last edited by SAJ; 02-04-2015 at 03:39 AM. Reason: can't spell siphon |
02-04-2015, 10:42 AM | #16 |
Gas gauge is a possible culprit. Replace the gaskets. That fix solved my 'evaporation' problem.
02-04-2015, 10:44 AM | #17 |
02-04-2015, 08:42 PM | #18 |
Nope. The gas was leaking down behind the instrument panel, but so slowly that there was never enough to drip on the floor - or my shoes.
Girl with dry toes. |
02-04-2015, 09:09 PM | #19 | |
Girl with sensitive nose |
02-04-2015, 09:31 PM | #20 |
