02-14-2012, 10:52 AM | #1 |
1939 Standard Front Splash Pan - photo?
Does anyone have a photo of a 1939 standard front splash pan...
I am missing one and just need to see what I'm looking for to compare to any that may be for sale... Would this be the same 37-39std? thanks Zach
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
02-14-2012, 11:17 AM | #2 |
Re: 1939 Standard Front Splash Pan - photo?
This pan?
02-14-2012, 11:22 AM | #3 |
Kube... the panel that would attach to the front crossmember going forwards toward the radiator...
Maybe there isnt supposed to be one? I have 2 bolts sticking down from my crossmember with nothing attached to them... assumed there should be a panel there to keep road grime off the distributor? thanks!
-WANTED-
02-14-2012, 01:11 PM | #4 |
Is this what you are looking for?
dickspadaro.com |
02-14-2012, 01:14 PM | #5 |
Thanks for the photo Dick,
I'm not sure.... I don't have one to compare to... is that the part that attaches to the front of the front crossmember? If so and its yours... is it for sale? thanks Zach this is what the EFV8 book shows... just trying to make sense of it... pn 81A-16550
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads Last edited by SUHRsc; 02-14-2012 at 01:20 PM. |
02-14-2012, 01:39 PM | #6 |
Cooling system parts pics show what you need, though not very well...standard is 91A-8240-A...kind of murky illustration. The different deluxe one has a clearer pic that suggests mounting to those crossmember tabs. How it relates to the 16550 in the fender section is entirely unclear...from the taper shown above I'm guessing it lives between the 8240 and the grill. Need to find the '39 chassis book. I'm not at all familiar directly with these late models... |
02-14-2012, 01:43 PM | #7 |
The one Dick is illustrating is the correct one for a 39 Standard.
02-14-2012, 01:46 PM | #8 |
thanks Bruce and Jerry
-WANTED-
02-14-2012, 01:50 PM | #9 |
02-14-2012, 04:15 PM | #10 |
Dick depicted the other pan that is correct for your car. That, along with the engine pans were it...
02-15-2012, 02:29 AM | #11 |
MEMBER EMERITUS
I'd like one also.
Chris.NZ. |
