01-02-2013, 01:22 PM | #1 |
Gas additive's
Do any of you recommend or use Sta-Bil to keep the gas preserved during the winter if you are not using your vehicle. I was recently told that this new gas starts to breakdown right around 30 days, and that this would keep it viable, if that's the word to use.
01-02-2013, 01:38 PM | #2 |
Re: Gas additive's
I use Sta-bil but prefer to drain the gas out if it is ethanol and it is going to sit for a few months or more. If I was planning a winter storage and wanted to keep gas in the tank I would fill it up with "clear" gas as the non ethanol is called, and add the recommended amt. of Sta-bil or
Seafoam |
01-03-2013, 08:40 PM | #3 |
Re: Gas additive's
I don't. My son had a very bad experience with it, gumming up the carb.
I have never used any type of stabilizer in any of my cars, now going on 25+ years and never had gas go bad to the extent it would not fire. I generally put gas in in Oct. or Nov. and don't add till March or April. I do start the cars about once a month and let them heat up to operating temp. This past summer I used two year old gas/oil mix for my weed whacker with no problem. All 10 % ethanol. |
01-03-2013, 08:48 PM | #4 |
Re: Gas additive's
I prefer Seafoam myself. OMO ken ct.
01-03-2013, 09:54 PM | #5 |
Re: Gas additive's
I have a 250 gallon tank of non ethanol gas on the farm. I add Sta-bil to the large tank, but don't put Sta-bil directly in any vehicle tanks.
Can't say that I've seen either good or bad things from using the Sta-bil. Tom |
01-03-2013, 10:19 PM | #6 |
Re: Gas additive's
01-03-2013, 10:34 PM | #7 |
Re: Gas additive's
I know a small engine repair man that says 30 days for the small engines, the ethanol seperates from the gas and draws mouisture causing rust or corrosion and plays havoc on some plastics and rubbers. He sells non ethanol which he admits is expensive but tells me to run carb dry and put just enough in to fill carb. I have been having trouble with my small engines and on my past Chevy 348 I had six holley 94s that the accelerator pumps swelled up and you could not push the gas pedal down. I called Charlie Price at Vintage Speed in Vero Beach Fl and he sold me accelerator pumps and I did not have any problem after that.
01-03-2013, 10:43 PM | #8 |
Re: Gas additive's
We spend enough money at the gas companys so why could they not write up an honest post about the pros and cons of ethanol in the fuel we use..
01-03-2013, 11:30 PM | #9 |
Re: Gas additive's
When the ethonalgas first came out I had problems with the car and lawnmower, last couple of years I have just pushed the mower into the shed---drug it out in the spring, 2 pulls and it was running, this past summer when we had the big wind that knocked out power the generator in the motorhome that had been sitting for 4 years was started and ran for 40 hours on the 4 year old gas, my A I just back into the garage and shut off ---
whatever toxic waste they are adding to the gas now seems to be reasonably stable. |
01-04-2013, 11:11 AM | #10 |
Re: Gas additive's
Go to your local air field with a gas can and get 5 gallons on 100 octaine low lead airplane fuel. Drain out the crap gas in your tank, put the 100 in, start it up and run for 15 minutes, shut it off and store it. No need for any additives. 100 octaine has a shelf life of 3 years.
01-05-2013, 09:55 AM | #11 |
Re: Gas additive's
When questioned. both Shell and Chevron will tell you that modern day fuels. both gasoline and Diesel have a shelf life of 60 days. The additives are so expensive that they use a minimun amount to save money. Corporate theory is you buy fuel to use it not store it! The gas of today will not start a trash fire in 2 years! Sta-bil and Seafoam will do their job but the base fuel is JUNK.
01-05-2013, 10:03 AM | #12 | |
Re: Gas additive's
01-06-2013, 01:16 AM | #13 |
Re: Gas additive's
Pete, just drive your car, and fill it with fresh gas!...LOL
Brendan
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
