Old 02-19-2011, 07:05 PM   #1
Mike in Mass
Mike in Mass's Avatar
Default 8 inch rear-end
hi all ! a buddy of mine is looking for an 8 inch rearend for his car I stripped and junked probably 30 ford galaxys back in the 80,s. mostly 63 s an 64 s would any of these have an 8 inch ? how can I tell? nothing older than 1964 the rear ends are up in the pucker brush . is there an easy way to tell will they still be good after 25 years thanks mike in mass
Mike in Mass is offline   Reply With Quote
Old 02-19-2011, 07:12 PM   #2
Herman Munster
Herman Munster's Avatar
Default Re: 8 inch rear-end
I don't know. You might want to pinch one to be sure. Problem is by that age, they're usually too fat and full of cellulite.
Sorry, I just couldn't resist poking fun at that post.
Herman Munster is offline   Reply With Quote
Old 02-19-2011, 07:26 PM   #3
28RPU
28RPU's Avatar
If you can get a socket on the bottom bolt under the pinion then its an 8 inch.If only an open end wrench or box end will go on it then its a 9 inch. 63/64 Galaxies had 9 inch rearends. The mid size Fairlane/Torino platform with the small block would have had the 8 inch.
After 25 years with condensation in it they may be rust pitted.Won't know until you pull a chunk out of your rearend .....
28RPU is offline   Reply With Quote
Old 02-19-2011, 07:30 PM   #4
Mike in Mass
yea after posting I knew I ,d be in for it oh jeeze there I go again !
Old 02-19-2011, 08:09 PM   #5
Herman Munster
Thanks for having a sense of humor, Mike.
Old 02-20-2011, 04:07 PM   #6
Jay in Mass
Mike
You didn't say what your friend is putting the 8" rear end into.
Ferreiras in Carver is where I got all of the 8" and 9" rear ends that I have needed. Give me a call when you are driving through so we can have coffee and I'll show you my collection.
Jay
Jay in Mass is offline   Reply With Quote
Old 02-21-2011, 10:14 AM   #7
georgewarren
Some cars with 8 inch rears to look for are the 62 and up V-8 Fairlanes, Torinos, Rancheros, (except 390s which sould have 9 inchers) Falcons with V-8s, Mustangs 64-70 with V-8s and big sixes, mavericks with V-8s and big sixes, Granadas and Monarchs (some will have 7.5 inchers, they will have removeable inspection plates, ala chevy 10 bolts). The narrowest will be 62-65 Fairlanes and 63-65 V-8 Falcons. Good luck!
georgewarren is offline   Reply With Quote
Old 02-21-2011, 10:18 AM   #8
Hamtown Al
Hamtown Al's Avatar
George, will the fairlanes be more narrow that the mavericks?
36 Fords Rule! Visit at www.36fords.com.
Hamtown Al is offline   Reply With Quote
Old 02-21-2011, 05:07 PM   #9
Fordknut
The Maverick should be the same width as the '63-'65 Falcon, '63-'65 Comet and the 64-1/2-66 Mustang which is about the the same width as the full size Fords from '49 thru '59. The '66 and up Fairlane/Torinos with sixes and 302s had the 8 inch but were wider. Any Fairlane/Torino with a 351 or larger engine has the 9" rear. I once owned a '65 Falcon Sprint in which the pinion seal was leaking. I installed the "punkin'" out of a '70 302 Torino because the casting is stronger and the bearing larger.
I have an 8" rear out of a either a '65 Falcon or '66 Mustang ( can't remember which) for $150.00. 50 miles west of Albany; 10 miles south of Cobleskill.
Fordknut is offline   Reply With Quote
Old 02-21-2011, 06:49 PM   #10
georgewarren
Al, if I remember my measuring correctly, the 62-65 V-8 Fairlane is the narrowest of the 8 inchers, except for maybe the 63-65 V-8 Falcon. That would make the narrowest 9 incher one from a hi-po 63-65 Fairlane. As you and I know, and for the benefit of those who don't know, the narrowest 9 incher will be from an early Bronco, like the one I sold to you for the 48 coupe that I later bought from you; what goes around, comes around!
Old 02-22-2011, 09:05 AM   #11
Ole Don
Ole Don's Avatar
If any rear axle has been laying on the ground in your climate, I would pass. Look in to a Ranger 8.8 axle if you cant find a good 8 inch. Be aware on the Rangers, they have big brakes, and small brakes. The small brakes were inadequate on a Ranger. The brakes interchange on the housings, just change the backing plates and drums.
Ole Don is offline   Reply With Quote
Old 02-22-2011, 01:33 PM   #12
Fordknut
I think the '57 to '59 Ford 9" rears were among the narrowest and were a direct bolt-in for the "shoebox" Fords, the '63-'65 Falcon/Comets and the '65' and '66 Mustangs.
' course, how many of them are you goin' to find nowadays? LOL
Old 02-22-2011, 03:37 PM   #13
pprather
pprather's Avatar
Send a message via AIM to pprather
The Mustang II with V8 used a narrow 8". Mine is from a 1978.
It was very close to the same width as the Pinto rear that it replaced in the old Vicky.
Phil
pprather is offline   Reply With Quote
Old 02-22-2011, 10:37 PM   #14
parklane
parklane's Avatar
Hey Phil, they let you in here too??
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
Old 02-22-2011, 10:48 PM   #15
Mike in Mass
THANKS for all the replies guys I could make a comment on how I,m really UP on my re-end knowledge ,but I don,t want to get HERMAN on me again , geeze again ! M in M
Old 04-08-2011, 11:27 PM   #16
aandkt
Try these Ford rears
Andy
Outside
Width
Year
Model
56.50
1969-1977
Maverick 8"
57.00
1974-1978
Mustang II 8"
57.25
1957-1959
Ford, Ranchero, Station Wagon
57.25
1965-1966
Mustang
58.00
1966-1977
Bronco
58.00
1964-1965
Falcon
58.00
1977-1981
Granada/Versailles
58.50
1977-1981
Versailles
59.25
1967-1970
Mustang, Fairlane, Comet, Cougar
60.00
1967
Cougar
60.00
1958-1960
Edsel
61.00
1964-1971
Ford Full Size
61.00
1949-1951
Mercury
61.25
1957-1972
Ford F-100 Pickup
61.25
1960-1964
Ford Full Size
61.25
1971-1973
Mustang
61.25
1967-1973
Torino, Ranchero, Fairlane
63.00
1970-1979
Ranchero & Torino
63.00
1972-1979
Ford Full Size & Intermediate
63.50
1967
Fairlane (Coil Springs)
aandkt is offline   Reply With Quote
Old 04-08-2011, 11:40 PM   #17
aandkt
To georgewarren and anyone with Bronco rear info.
You mention Bronco rears. I have a early Bornco rear, about 1974, their pinion is about 1" to the right of center on them. How does it function in your 48? Is there anything special needed in relation to the driveshaft angle? I plan to put it in my36 Convert.
Thanks
