Old 03-03-2014, 02:56 PM   #1
ole_Bill
ole_Bill's Avatar
Default Replacing '46 sedan speedometer cable
Imagine my surprise when I pulled the speedometer cable from my 1946 2-dr sedan and found it was only 22 inches long. No wonder the speedometer had not been working. So now I need a new cable and some instruction on how to get out the piece of cable that is still in the metal cable run. I assume it will have to come out from the transmission end....how do I do that?
"I ain't no mechanic, my posts should make that obvious, I'm jus doin my best with what I got."
ole_Bill is offline   Reply With Quote
Old 03-03-2014, 03:39 PM   #2
41 Fords ohio
41 Fords ohio's Avatar
Default Re: Replacing '46 sedan speedometer cable
You should be able to unscrew the other end at the trans. Once you get it off you should be able to take a pair of needle nose pliers and pull the rest of the cable out. If it's stuck inside of the housing. You might have to soak the housing in some PB Blaster for a few days
When will I be old enough to know better?
41 Fords ohio is offline   Reply With Quote
Old 03-03-2014, 03:51 PM   #3
oldskool
oldskool's Avatar
you might be better off replacing the whole cable and casing there not that expensive $15-25 range,yours may have a kink or bad spot
oldskool is offline   Reply With Quote
Old 03-03-2014, 04:32 PM   #4
Ralph Moore
Ralph Moore's Avatar
Speaking of speedo cables, where is a good source for them?
Ralph Moore is offline   Reply With Quote
Old 03-03-2014, 04:43 PM   #5
deuce lover
deuce lover's Avatar
Got mine(cable & casing $22.95 ) at The Early Ford Store in San Dimas,CA 909-305-1955.He does use USPS for shipping.It will fit in a flat rate envelope($5.80).
deuce lover is offline   Reply With Quote
Old 03-03-2014, 05:00 PM   #6
Steves46
Steves46's Avatar
Agree with replacing the cable/casing. I got mine from C & G and it fit perfectly. I'm pretty sure most of the parts places get the cable & housing from the same supplier.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
