07-05-2015, 05:47 AM | #1 |
Replacing '40 Ford Clutch
This is a very basic question, but I never pulled a trans from a closed drive system. What's the first thing you have to do ? Pull the whole rear axle ?
Thx...Mike |
07-05-2015, 06:21 AM | #2 |
Re: Replacing '40 Ford Clutch
I'd rather pull the engine to change the clutch. Walt
07-05-2015, 07:26 AM | #3 |
Take out the front seat
Remove the floor boards I have an extra long flex brake line so i dont have to disconnect the line to slide back the rear end Or you could pull the engine Either way is ok I just did not have an engine hoist |
07-05-2015, 07:45 AM | #4 |
It might depend on how your shop is set up. Moving the rearend back is much faster than removing the engine if you have all the tools, facilities, and conditions available to do either job efficiently.
07-05-2015, 07:51 AM | #5 |
My 38 needs a flywheel ring gear so I may as well replace the clutch while I'm at it. I plan on pulling the engine when I get the ambition. Pulled a A/T out of a old Rambler that still had a closed driveline way back in the 60's when I was young and could move around. It was a PITA. Can't imagine doing one now. It's a major pain anymore getting up & down from the floor anymore.
Dan Kingman Az. 86409 |
07-05-2015, 07:53 AM | #6 |
Just my recommendation .. Others may differ Larry |
07-05-2015, 08:32 AM | #7 |
If I am replacing a clutch, I prefer to pull the engine because many times the flywheel needs to be resurfaced, unless you happen to have a two piece truck oil pan that allows removal of flywheel. It has always been a nightmare for me to remove an oil pan with the engine in the car. If I am say just removing a transmission, I prefer to pull the rear down and roll it back to get the trans out.
07-05-2015, 10:34 AM | #8 |
Done it both ways but for me it is easier to pull the engine than move the axle,,,realignment is hard unless you have a rack
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
07-05-2015, 10:56 AM | #9 |
Mike 42, If you pull the engine you will be able to repaint the engine compartment and won't have to bleed the brakes.
07-05-2015, 11:02 AM | #10 |
Personally, I avoid pulling the engine like a plague. I prefer sliding the rear end back and dropping the oil pan if flywheel needs resurfaced. If you decide to do that here are the step by step instructions. Of course, to just remove the fly wheel you don't need to totally remove the oil pan, i.e. you don't have to drop the radius rods, just drop the pan down enough to get the flywheel off.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 07-05-2015 at 11:09 AM. |
07-05-2015, 02:37 PM | #11 |
On another note My 40 has been apart so many times that I dont have to fight with any fasteners. Now remembering how it goes back together is another story. Dont forget the cover on the U-joint!!
07-05-2015, 03:40 PM | #12 |
After restoring my 40 wagon, the new BCA throwout bearing lasted 7 miles before it sounded like a coffee can full of marbles. Yes, I had plenty of free play on the pedal. (New no longer equals good) Anyway, I pulled the engine. Left the hood on and removed the radiator, and grille. It was pretty easy since everything was fresh.
07-06-2015, 05:43 AM | #13 |
Well.....no matter which way I go it'll be a pain in the butt I can see ! I think I'll have someone do it for me !
Thx very much Mike |
07-06-2015, 09:39 AM | #14 |
Mike42, try to get someone who has worked on flatheads before.
