11-10-2012, 12:03 PM | #1 |
Ever wish you knew more precisely what your engine temperature is?
I have too many times. So, I decided to install a mechanical temperature gauge on the left side of the engine so it would read that side more precisely and left the dashboard gauge to read the right side as it has always done. Can you find my second gauge in my dashboard?
Here it is: I didn't want it distracting from the authenticity of my dash board so I put it in the glove box to be able to check it when I want to or just leave the glove box open if it's at a critical temperature and I want to watch it. Otherwise, it's out of site. Installation was less than 30 minutes. Only hole I needed to cut was in the back of the glove box. Sensor passed through my steering column hole with ease. And ran right up to the left side sender port. I know, it's distracting from my authentic engine compartment. I'm going to cover the tube with black friction/cloth tape so it won't stand out so much. Gauge cost $17.95 at AutoZone. I tested it's accuracy in heating water on the stove with its sensor and my wife's candy thermometer in the water. It read about 5-7 degrees higher than the candy thermometer which is good for it being in the left side of the engine that's usually about that much cooler than the right side so that I really do get a pretty accurate reading of the hotter right side. Just thought someone might like to know.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 05-03-2013 at 11:04 PM. |
11-11-2012, 05:04 AM | #2 |
Re: Ever wish you knew more precisely what your engine temperature is?
That's a sweet looking interior.
11-11-2012, 08:07 AM | #3 |
Nice idea. I have a tach that I may stick in the glove box. Once you mentally adjust to the new numbers corresponding to the dash gauge, or the sound of the engine to the actual tach gauge you need not look at it every minute.
Mechanically Inclined but not Auto Familiar |
11-11-2012, 08:08 AM | #4 |
Good idea to stash in the glove box.. I have a mechanical oil pressure and temp gauge set up... I might copy you and move the gauged to the glove box...
11-11-2012, 08:18 AM | #5 |
did the sensing line come with the gauge?....Thanks...Jack
11-11-2012, 09:22 AM | #6 |
11-11-2012, 10:02 AM | #7 |
I did the same thing to my '46 but didn't hide the gauge. Nice touch!
11-11-2012, 10:02 AM | #8 |
What I did on my "40" was to use velcro on the top of panel and bottom of dash so I can put gauge behind dash when I did not want in sight.
11-11-2012, 10:15 AM | #9 |
Yes. It is actually an integral part of the gauge because it's connected to the gauge with a capillary tube filled with fluid of some kind that transfers the pressure caused by heating up the sensor bulb to the diaphragm in the gauge that deflects the needle. Can't be seperated or system is destroyed. That's why I had to pass the sensor bulb through the steering column hole. Otherwise I'd had to cut a one inch hole in the firewall to pass the sender bulb through then try to seal that huge hole up around the tiny tube.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 12-12-2013 at 12:25 AM. |
11-11-2012, 12:45 PM | #10 |
I like to know what each side is doing....never too much information!
11-11-2012, 01:48 PM | #11 |
Here is what I did on my '41 Pickup.....the temp is virtually the same for both sides.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS..... http://s818.photobucket.com/home/roglehr/index |
11-12-2012, 09:15 AM | #12 |
I know exactly what the temperature is on all of my old Fords when I drive them. I use Skips pumps on all of my Fords and contrary to what others report ALL of mine run within 2 or 3 degrees on both sides. There are no new type thermostats or washers that do not restrict the flow which increases temperature. I have Bob Shewman's [email protected] 180 degree FULL FLOW stats in the hoses of 3 39's and they all run within 2 degrees of 180 on both sides from 45 degree to 95 degrees outside temperatures. I have done a lot of heat testing on these cars over the past 15 or more years on both the cooling and fuel systems. I have 3 or 4 laser pointed thermometers with one on the old car and my diesel p/u at all times. The 0nly really important temperature is on the buldge of the 32 to 36 years right behind the water pumps, on the neck of the water outlet just below the hose on 37 to 48's and on the goose neck of the outlet on 49 to 53 years. The gun has to be held same distance from the test point and at the same angle hitting the same spot each time temperatures are taken. After a few times testing is done under the same driving and outside temperatures conditions compairing these results with the dash gauge you will know exactly when a change occures and what your gauge is reading. With a one sided temperature sender it measures that side of the engine which it is installed in. If one side starts to get warmer it raises the water temperarure in the entire system and shows a higher temperature on the single gauge. This single gauge has worked for 70 plus years. As most of you know the internal water system in the block consists of 2 seperate cooling systems each with it's own pump. The water is mixed together only in the radiator. G.M.
www.fordcollector.com |
11-12-2012, 10:28 AM | #13 |
Oh boy!!!???
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
11-12-2012, 10:43 AM | #14 |
Oh boy!!!???
sometimes the simplest answers are the best answers. thanx, old henry, i`m still laughing. tom |
11-12-2012, 12:29 PM | #15 |
If you can't dazzle them with brilliance then baffle them with bull s--t!
11-12-2012, 01:02 PM | #16 |
11-12-2012, 01:08 PM | #17 |
I don't get it. I just don't get the connection between using Skips pumps and knowing exactly what the temperature is. I've heard claims they move a lot of water but report temperature too? I just don't get it.
11-12-2012, 02:35 PM | #18 |
Once again great information from old'henry and as a reply from GM a sales pitch about Skip. GM it's OLD and a pain in the a** to everybody reading the threads. Yes GM, WE KNOW, WE KNOW. Drop the pitch!
1939 Fordor Deluxe 1939 Ford Coupe Std 1940 Ford pickup Nothing in life is to be feared; it is only to be understood. Last edited by gmc1941; 11-13-2012 at 11:02 PM. |
11-12-2012, 09:19 PM | #19 |
I was wondering about that myself.
I dig coal, which provides motivation for EVs. |
11-12-2012, 11:03 PM | #20 |
Thanks old Henry call me dumb..but what is "black friction/cloth tape "?
Always enjoy your posts ..thanks a bunch Randy |
