Old 03-07-2014, 02:46 PM   #1
Old Henry
Old Henry's Avatar
Default What's causing this squeak?
It's in the back end. Sounds like in the middle somewhere. The car is in gear. http://youtu.be/xZdX1ULUwPs
What do you think is causing it and what to do about it?
Old 03-07-2014, 02:54 PM   #2
BILL WZOREK
BILL WZOREK's Avatar
Default Re: What's causing this squeak?
I don't know what it is but I bet it is tied to your VIBERAZTION !?!?!?!?!?
BILL WZOREK is offline   Reply With Quote
Old 03-07-2014, 02:57 PM   #3
G.M.
I think you should jack the radiator cap up and drive another car underneath It. G.M.
www.fordcollector.com
Old 03-07-2014, 02:59 PM   #4
Mart
Mart's Avatar
Long shot, but easy to do, try it with the hubcaps and trim rings removed, and check the wheel nuts and hub nut for tightness.
You don't think it's the pesky rear couple pin problem, do you?
Mart.
Old 03-07-2014, 03:01 PM   #5
Seth Swoboda
Seth Swoboda's Avatar
Have you checked out wheel bearing grease lately, or do you have a break shoe that is rubbing the drum slighty?
Seth Swoboda is offline   Reply With Quote
Old 03-07-2014, 03:10 PM   #6
peewee2you
peewee2you's Avatar
Sounds like possible issues with emergency brake or brake shoes like Seth said..
peewee2you is offline   Reply With Quote
Old 03-07-2014, 03:28 PM   #7
oldford2
oldford2's Avatar
Sounds like a broken shoe spring. Jack it up and turn by hand. Looks like you should pull the drum rather than have us all guess. You probably could have pulled the drum in the time it took you to make/post the video.
John
oldford2 is offline   Reply With Quote
Old 03-07-2014, 04:07 PM   #8
Old Henry
Old Henry's Avatar
I'll be pulling all drums to grease the bearings tomorrow for the 10,000 mile maintenance. (Just hit 230,000 miles)
Old 03-07-2014, 04:08 PM   #9
Old Henry
Old Henry's Avatar
Ah, now I get it. I've always wondered why you had so darn many vehicles sitting around your place and only one radiator cap. But, don't you eventually run out of replacement vehicles and actually have to stop and fix one?
Old 03-07-2014, 04:29 PM   #10
oldford2
oldford2's Avatar
"I'll be pulling all drums to grease the bearings tomorrow for the 10,000 mile maintenance. (Just hit 230,000 miles)"
Professor, Good move. Let us know what you find. John
Old 03-07-2014, 05:19 PM   #11
4dFord/SC
4dFord/SC's Avatar
Sounds like the front porch swing to me. Where are you parked?
4dFord/SC is offline   Reply With Quote
Old 03-07-2014, 06:10 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
Possibly a Johnson rod bushing that the pit guy missed at Jiffy Lube? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-07-2014, 06:26 PM   #13
uncle max
uncle max's Avatar
Best answer yet!!!
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 03-07-2014, 09:10 PM   #14
APDAVE
I have heard similar noises from loose lug nuts, how about your axle nut torque! Dave
APDAVE is offline   Reply With Quote
Old 03-08-2014, 05:09 AM   #15
john mullen
john mullen's Avatar
^^^^^ lug nuts.....
john mullen is offline   Reply With Quote
Old 03-08-2014, 06:36 AM   #16
Snouts out
It sounds like a bad open drive shaft u-joint,& if it's not,I'll bet Prof knows what it is!
Snouts out is offline   Reply With Quote
Old 03-08-2014, 07:59 AM   #17
G.M.
I very seldom have to stop and fix one I fix them right the first time. G.M.
Old 03-08-2014, 07:59 AM   #18
flatford8
flatford8's Avatar
Did these latest issues start after you ran it thru that 2ft. mud hole????.....Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 03-08-2014, 08:04 AM   #19
Mart
Mart's Avatar
What happens if it is in neutral and you roll it back and forth? If you still get the noise it is probably something to do with the brakes. I suspect it is not the brakes as the noise happens when the motion of the car is stopped by the slack being taken out of the driveline.
Any progress yet?
Mart.
Old 03-08-2014, 09:12 AM   #20
Sid the Maineiac
Sid the Maineiac's Avatar
I'd guess something loose in the brake dept,If lugnuts making noise like that you should see some wheel wobble I would think .Same with axle nut !I wouldn't go far till I knew what it was just so you don't cause more damage to car or you !! Good luck with it.May your problem be small !!
Sid the Maineiac is offline   Reply With Quote
Thread Tools
Display Modes
