Old 08-08-2015, 12:03 PM   #1
houseof34s
Default 40 ford fedender welting installation
What is the correct installation of fender welting on 40 ford deluxe.
Specifically the top and bottom ends as the new Fords came of the assembly line?
houseof34s is offline   Reply With Quote
Old 08-08-2015, 02:07 PM   #2
Kube
Kube's Avatar
Default Re: 40 ford fedender welting installation
Front fenders : the top was merely folded over to offer a somewhat "finished" appearance. The lower edge was simply cut off with little care as to how close or how far away (the cut was) from the bottom edge of the fender.
Rear fenders: Little care was taken at either the front or rear ends of the welt when it was cut off in regard to how close (or not close) it was to the end of the fender.
Old 08-08-2015, 02:21 PM   #3
houseof34s
Thanks
Are there any drawing and intructions available from ford archives to your knowledge?
Old 08-08-2015, 03:42 PM   #4
Kube
Kube's Avatar
Thanks
Not that I am aware of. However, there are numerous factory photographs that depict what I had conveyed to you earlier.
Old 08-08-2015, 05:05 PM   #5
houseof34s
Thanks again <> l will do some checking.
Old 08-08-2015, 10:59 PM   #6
fordor41
fordor41's Avatar
When I install welting I glue it in place either on the body or fender and at the bottom I fold it over and attach it down with the smallest pop rivet I can find. Usually there isn't a bolt at the very end and the welting can work loose after the bolt and hang down
fordor41 is offline   Reply With Quote
Old 08-09-2015, 10:39 AM   #7
Fred A
Fred A's Avatar
What about those staples that holds the welting to the fenders? Seems that the factory had no time to wrestle the welt into place as we are left to do. Probably no modern way to do those hard round staples. I regret pulling them out. Good Luck: Fred A
Fred A is offline   Reply With Quote
Old 08-09-2015, 11:21 PM   #8
fordor41
fordor41's Avatar
On my '41 most of the welting around the grill area was stapled to the metal
Old 08-10-2015, 09:37 AM   #9
19Fordy
19Fordy's Avatar
I know it isn't "factory" but it looks better when you cut a "V" in the welting where the fender ends and fold it back upon itself. That gives you a nice round radius at the corner.
Thread Tools
Display Modes
