03-21-2011, 08:34 PM | #1 |
What type of additive to add to water
It's starting to get that time of the year. I plan on draining the antifreeze and running straight water because it's been my experience that water runs cooler.. What is a good additive to add to protect the engine from rust and to lube the water pumps.
03-21-2011, 11:18 PM | #2 |
Re: What type of additive to add to water
the best thing you can do for the engine is run a 50-50 mix of antifreeze all year, it has rust inhibators in it, and it will also lube the water pump seals. so why change it?
03-21-2011, 11:36 PM | #3 |
Keep the antifreeze it is designed for all season.
Ronnie |
03-22-2011, 01:32 AM | #4 |
