03-20-2011, 01:17 PM | #1 |
Windshield Glue
I have a new windshield and weatherstrip for my 49 F1,the manual says to use rubber cement around windshield to weatherstrip.Is there a certain type of sealant I should use and how do you apply it?
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
03-20-2011, 01:57 PM | #2 |
Re: Windshield Glue
I think you would use one that dosent dry a soft sealer.
03-20-2011, 03:13 PM | #3 |
Re: Windshield Glue
I use the black windshield sealant from Napa. It's part #4121. I use it to seal around the glass to the gasket and the gasket to the body. Tape around the opening to protect the paint and glass with masking tape and it minimizes the cleanup
03-20-2011, 05:11 PM | #4 |
Re: Windshield Glue
To follow up on TJ: I applied this to both the grove in the rubber where the glass goes and also around the perimeter under the rubber after I installed the rubber. I probably over did it, but it never leaked in 23 years. Wipes clean with mineral spirits.
03-20-2011, 08:36 PM | #5 |
Re: Windshield Glue
Most often put the glass and rubber in without sealer. Water check it. If it doesn't leak leave it alone - if it leaks seal it. Quite often you won't need to seal it.
03-21-2011, 01:11 AM | #6 |
Re: Windshield Glue
03-21-2011, 08:47 AM | #7 |
Re: Windshield Glue
Fibber, did you buy the weather strip cement(glue) or a sealant? They are two different products. The 3M glue is used to glue the weather strip on your doors,etc. The window sealant is flexible ( is thicker to take up wider gaps) and used on the window gasket to seal out water.
03-21-2011, 11:31 AM | #8 |
Re: Windshield Glue
I'm sorry it was the sealant,I don't know why I said glue.
