10-12-2011, 04:48 PM | #1 |
Pictures of 57 T-Bird Fuel & Vacuum Lines?
In the process of installing 57 TBird intake, carb, and distributor on my 56 Bird. Need a little help. Fuel lines and vacuum lines are different from my originals of course. I ordered stainless steel lines from a T-Bird parts house. My experience in the past has been that these repros can be pretty far off. These are far enough off that it's hard to figure out where they should be routed and how they connect.
I was wondering if there is anyone out there in the Barn who has a reasonably correct 57 T-Bird, 312 with a single quad (original type Holley 4150) who can take some close-up shots of this area (with the air cleaner removed) and send them to me. I sure would appreciate the help. I particularly need to see the connections such as the vacuum lines to the block fitting on the intake manifold. Thanks in advance for any help anyone can provide. |
10-15-2011, 09:18 AM | #2 |
Re: Pictures of 57 T-Bird Fuel & Vacuum Lines?
I have a dead stock '57 Bird with the Holley 4 barrel... I will take some pix of the fuel/vacuum lines today.. The pix will also show how I hooked up the PCV system from a '64 Ford 292 trk onto my 312.
The attached pix don't show very good detail..they are just for a general idea of how the engine should look. Kinda gives you something to dream about. I hope you are aware that you will not be able to use the original '56 distributor with the Holley.. The later model 292 distributors will work, however, you will loose the tach drive feature..
Bill.... 36 5 win cpe |
10-15-2011, 04:12 PM | #3 |
Bill... Appreciate your help. I located and acquired the correct 57 components including carb, intake manifold, and tach drive distributor.
10-15-2011, 07:30 PM | #4 | |
10-18-2011, 11:18 AM | #5 |
I guess I will have to have a local expert on early Birds look at my car and the PB booster in particular....Of course it really don't mean spit to me, because I gave showing the car many years ago...Bill
