12-06-2016, 02:13 PM | #1 |
35 coupe tool box
anybody got a blueprint of the original 35 coupe rear fender tool box---thanks
12-06-2016, 05:57 PM | #2 |
Re: 35 coupe tool box
here
12-06-2016, 05:59 PM | #3 |
two
12-06-2016, 06:01 PM | #4 |
three
12-07-2016, 06:43 AM | #5 |
This is the 35 tool box. The dimensions are slightly different than the 34. Note the cut out for the drain tube on the rear window rain gutter. I do not have dimensions.
12-07-2016, 07:44 AM | #6 |
How about the roadster or cabriolet? |
12-07-2016, 08:06 AM | #7 |
Early 35 Coupe and Cabriolet with Rumble seat. Eliminated in March of 35.
12-07-2016, 03:24 PM | #8 |
I don't think That's the drain Terry that's the jack handle cut out ,Ted
12-07-2016, 05:02 PM | #9 |
The 34 tool box does not have the cut out and it's jack handle with one bend is longer than the twice bent 35 jack handle. without the cut out it would be nearly impossible to install the tool box without bending the drain tube. The larger tools were stored under the front seat or in the case of the Cabriolet there is a second tool pouch sewn into the LH rubble side panel.
12-07-2016, 06:34 PM | #10 |
The upright support is about 4,1/2 from the end of the box ,1935
12-07-2016, 10:25 PM | #11 |
jjjjjjjjjjjjjjjj
12-07-2016, 11:56 PM | #12 |
Didn't even know this existed!?! Thanks everyone for the photos and specs
Seabright Hot Rods |
