Old 08-09-2015, 01:49 PM   #1
46ford
46ford's Avatar
Default Got my radio working!
The radio in my '50 hasn't worked in probably many years. I replaced the vibrator unit and a few capacitors, and a couple burned out resistors, and it works again! Probably less than $40 in parts and maybe two hours of my time.
Next project: get the Borg clock working again. The owners manual for the clock was attached to the clock with a loop of twine. "World's finest automotive timepiece" according to the label.
46ford is offline   Reply With Quote
Old 08-09-2015, 03:56 PM   #2
jack orchard
Default Re: Got my radio working!
Congrats on the radio repair. Not too many people would attempt to fix a radio like that. Done in 2 hours! You are now qualified as an expert. Did you use one of the newer solid state vibrators?,...jack
Proud FNG
We fixem cars. Heap Good!
jack orchard is offline   Reply With Quote
Old 08-09-2015, 04:09 PM   #3
Lawson Cox
Lawson Cox's Avatar
Does it play 50's music? LOL
Old 08-09-2015, 08:30 PM   #4
46ford
46ford's Avatar
Yes, used a solid state. Kinda wierd not hearing the vibrator until it warmed up.
I've fixed quite a few vintage radios, but this is my first car radio repair.
Old 08-09-2015, 09:44 PM   #5
34pickup
34pickup's Avatar
Thats great. Now you can listen to all those great AM radio stations that are so popular now days.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 08-09-2015, 11:31 PM   #6
Mike in AZ
Mike in AZ's Avatar
congratulation on your do-it-yourself repair....enjoy your music....Mike
Mike in AZ is offline   Reply With Quote
Old 08-09-2015, 11:38 PM   #7
Drbrown
Drbrown's Avatar
What process did you use to determine what was defective ? The vibrator in my '47 makes noise but nothing happens. Where do you buy your parts ?
Drbrown is offline   Reply With Quote
Old 08-10-2015, 04:26 AM   #8
46ford
46ford's Avatar
First I did some reading online and determined which parts of the radio are most likely to fail. There are a couple resistors in the vibrator circuit, and a buffer capacitor. One of the resistors was burned (measured open) and the vibrator was stuck, probably the cause of the burnt resistor. I replaced the resistors and cap, tested the radio and nothing, but the resistors were getting hot instantly. Replaced vibrator and all was well.
The car was in such good shape I figured one component must've failed, the owner replaced and blew the fuse a couple times and gave up. Car was last registered in '72 and thankfully no one had tried to fix the radios. My best success with antique radios is on the ones no one has tried to "fix".
I buy parts online from Ebay or parts dealers, nothing special.
