11-27-2015, 03:19 PM | #1 |
'41 slot in center grill??
is the 41 intended to have an optional hand crank start option? The hole in the center of the grill suggests a crank handle could be inserted there. I don't see where the connection would be made to the engine though.
11-27-2015, 03:28 PM | #2 |
Re: '41 slot in center grill??
Yes, the hole is for a hand crank. 1941 was the last year for them. The connection is on the front of the engine at the crankshaft pulley. I don't have a crank for my '41,but that's how it works.
11-27-2015, 05:04 PM | #3 |
the radiator has an opening to allow the crank to pass through to connect with the dog on the crank. When I bought my 41 the radiator did not have the opening.
3 pedals, 3 gears, no valve-covers.. Now THAT is a hot rod !! https://www.youtube.com/watch?v=ZmwwB34vxJE |
11-29-2015, 07:55 PM | #4 |
Does anyone have a picture of the crank?
11-29-2015, 08:08 PM | #5 |
'42 and i'm pretty sure '46 had apertures for Crank handles too.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand https://www.fordbarn.com/forum/album.php?albumid=580 |
11-29-2015, 08:31 PM | #6 |
11-29-2015, 08:31 PM | #7 |
I just checked my engine which is an 8BA in the 41. The crank is lower than the hole in the radiator. Now to figure out if the radiator is incorrect as well.
11-29-2015, 08:43 PM | #8 |
My '41 has a split radiator. The split goes down to where the crank is inserted to crank the engine. There it has a square hole for the crank to pass through. Not sure why your
crank hole does not line up. |
11-29-2015, 08:47 PM | #9 |
Both my 46s have the crank hole and a stabilizer or protection bracket riveted to the crossmember and the radiators have an indentation in the center bottom of the rad, tanks for a crank access, I gave the crank handle to my pickup away about 40 years ago (big mistake)
I heard too many stories about kick back and was not planning on using a hand crank on anything. Fordestes, |
11-29-2015, 08:50 PM | #10 |
Thanks for the feedback. It will take a while, but I will post pics in the future.
11-29-2015, 08:52 PM | #11 |
I think that you will find that the radiator sits higher in the V8 '42 and '46 so the crank handle goes under the radiator. The Six cylinder Radiator is lower and has a hole in it for the crank handle.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand https://www.fordbarn.com/forum/album.php?albumid=580 Last edited by meric42; 11-29-2015 at 10:14 PM. |
11-29-2015, 08:54 PM | #12 |
I just checked and my model A crank is not long enough for my 41 with the split radiator or the 8ba engine did not include a crank pulley that can be cranked!
11-30-2015, 10:44 AM | #13 |
I might be wrong but I thought I'd heard that the jack handle was also used as the crank.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
11-30-2015, 11:12 AM | #14 |
"Z" shaped lug wrench has a square hole in one end for an extension. The extension engages the dogs in the pulley bolt. Extensions came in several different lengths. Job Lot had new extensions for sale just a few months ago.
11-30-2015, 11:15 AM | #15 |
I have this one for my 38. No idea the year it's really for.
11-30-2015, 12:22 PM | #16 |
Ford had crank handle openings in pickups all the way up to 1952
Thee Inland Emperors |
11-30-2015, 10:17 PM | #17 |
The hand crank extensions were standard equipment through Sep 1936. After that they were considered optional but could be purchased from Ford if wanted. By 1940 they were only available to "northern" cars. After 1940 they more or less disappeared. The extensions were almost yearly specified so there were specific lengths and part numbers by year.
