11-18-2019, 11:59 AM | #1 |
Reinstalling aluminum head questions
8ba Felpro MS8903 gasket. 1 question- hi-temp grease on head & block or nothing? 2 question-do all head bolts get thread seal to prevent coolant seepage or just specific positions?
Nomad |
11-18-2019, 12:13 PM | #2 |
Re: Reinstalling aluminum head questions
MS 8903 is an intake gasket. Here's some answers.
https://www.fordbarn.com/forum/showthread.php?p=827228 Do a HEAD GASKET SEALER "Search" and much info. will appear. Also, check out BEST head gaskets. I use Permatex non-hardening thread sealer on all the head bolts. DO NOT CHASE HEAD BOLT THREADS WITH A TAP as they are Henry's special clearance fits. Cleaning out these threads with tap will increase chance of leaks. Don't clean head bolt threads with a "die" either for the same reason. Last edited by 19Fordy; 11-18-2019 at 12:23 PM. |
11-18-2019, 12:18 PM | #3 |
Oops, right! Sorry bout that, s/b 7525B my own scribbling messed up. Should of gone into garage
Nomad |
11-18-2019, 12:29 PM | #4 |
Peruse all the threads here for info. you need. You want to use a sealer that is easily removed. Otherwise, head removal will be more difficult.
https://www.fordbarn.com/forum/forumdisplay.php?f=4 Here's another thread on head sealant. https://www.fordbarn.com/forum/showthread.php?t=272754 Last edited by 19Fordy; 11-18-2019 at 01:28 PM. |
11-18-2019, 12:52 PM | #5 |
If you put sealer on some bolts and none on others it will change the torque values between the bolts. Bolts torque differently dry vs lubricated.
11-18-2019, 02:02 PM | #6 |
(Add) We use Permatex #1 (hard-setting) on all our builds here, bolts or studs! Thanks, Gary in N.Y. P.S. The washers are 7/16" x .675" x .065", and they are chamfered for use with bolts. They go on just about every Flathead we do here and many other builds, I sell/ship hundreds during the year! Maybe even a thousand or more?
http://www.stromberg-bulletin.com/me...berg-equipped/ Last edited by GOSFAST; 11-18-2019 at 02:04 PM. Reason: Add info |
11-18-2019, 06:38 PM | #7 |
I think you would use spray on copper permetex gasket
11-18-2019, 07:01 PM | #8 |
Researching thread 19Forty posted noticed one post indicated to leave engine sit 24 hours before starting to let thread sealant, I’m using Permatex w PTFE Thread sealant to set up. Saw nothing on label about cold temp sensitivity & My garage isn’t heated, will it prevent the thread seal from setting? Read label nothing about cold temp sensitivity? My garage isn’t heated?
Nomad |
11-18-2019, 07:34 PM | #9 |
According to this sheet it's not temp. sensitive.
http://www.worldpac.com/sdmedia/pdfs/permatex/56521.pdf |
11-18-2019, 08:13 PM | #10 |
The washers are standard 7/16 grade 8 SAE hardened washers available at Fastenal or MCMaster Carr for example. Using aluminum heads, I would apply a graphite/petrolatum anti-seize to the shanks of the studs or cap screws to prevent corrosion between the head and steel stud or cap screw. Aircraft & Spruce has it. The heads will come off easily at a later date.
11-18-2019, 08:32 PM | #11 |
Thx
Nomad |
11-19-2019, 10:24 AM | #12 |
Sorry 4 the inexperience & probably another dumb question. After cleaning out the head bolt thread holes in block is blowing them out w compressed air or shop vac better? Thinking don’t want debris entering the ones that go thru water jack potentially fowling the coolant flow & air pressure bad idea?
Nomad |
11-19-2019, 10:30 AM | #13 | |
11-19-2019, 11:31 AM | #14 |
I would use a vacuum cleaner as a last step after air hose.
11-19-2019, 11:48 AM | #15 |
thx
Nomad |
11-20-2019, 10:54 AM | #16 |
Last question on this, Promise! I’ve seen different preferences for thread sealants. Naturally in one thread the preference was Permatex w PTFE so I bought a bottle, as a result of follow up questions on sequence of install I saw some liked some not? Should I use or is there another preferred sealant most like?
Nomad Last edited by AnthonyG; 11-20-2019 at 10:56 AM. Reason: Typo |
11-20-2019, 11:15 AM | #17 |
Every person has their own preference . . . you can use a variety of products and they'll all work. What you have will work fine. As noted, I prefer to let the engine sit for at least a day before I fire it up - tends to allow the stuff to set in a bit. Make sure you put assembly lube on the stud/bolt sides and use hardened washers (you can get them from Jegs or Summit - different ODs, etc).. Always put some thread lubricant on both sides of the washers to help prevent galling. I use primarily ARP lubricants on fasteners.
11-20-2019, 11:15 AM | #18 |
Use it.
11-20-2019, 11:20 AM | #19 |
I used this sealant 6 months ago. Works fine.
Have also used Permatex non-hardening sealer. However, i see where others use Permatex hardening sealer. |
11-20-2019, 11:28 AM | #20 |
Will install today & cross fingers
Thx all
Nomad |
