05-20-2023, 08:56 PM | #1 |
rear axle interchange
I need to know if a 30 brake set up will swap over to a 28/29 axle , I have a line on an early rear axle that I am wanting to use the later rear brakes ,will the complete rear brakes with the wider emergency brake drums fit without any modifications work on my 30 coupe? appreciate it as always! Fordestes
05-21-2023, 11:01 AM | #2 |
Re: rear axle interchange
I tried to do what you want to do. So I found that the backing plates for a 30 31 will not bolt to the early rear axle housings. The bolt pattern is the same but the early axle housing is made with a small hump of metal sticking out in such a way that the 30 31 backing plate will not bolt up flush. So I changed the complete rear end. At some point during production in 28 29 they may fit not sure of that. Many changes were made as the years went by.
05-21-2023, 05:07 PM | #3 | |
