09-21-2019, 11:29 PM | #1 |
32 to 48 v8- are fuel pumps the same
Can I buy any rebuilt v8 fuel pump 32 to 48 and expect it to be correct ??
09-21-2019, 11:37 PM | #2 |
Re: 32 to 48 v8- are fuel pumps the same
That's a pretty wide open question. Can you narrow it down some?
Alan |
09-21-2019, 11:49 PM | #3 |
The Green Bible lists 59A 9350-A as fitting 1932-1948 passenger 90 and 100 HP. This says it should work but not necessarily be correct for a high point restoration.
Charlie Stephens |
09-22-2019, 12:51 AM | #4 |
Been a long time but I think I bought what was listed as a 34 pump for my 46 59 AB, does not have the sediment bowl.
09-22-2019, 10:05 AM | #5 |
Only with '34 or later intake manifolds and fuel pump stands/oil filler tubes. '32 and '32 intake manifolds require modifications plus the '34 and up fuel pump stand/oil filler tube and a different fuel pump push rod. The fuel pump to carburetor line on '32-'33s would also have to be modified or replaced.
It would be helpful if you stated what engine and intake manifold you have in mind as well as what you mean by "correct"; functionally speaking or as built? |
09-22-2019, 04:27 PM | #6 |
09-22-2019, 04:38 PM | #7 | |
Charlie Stephens Last edited by Charlie Stephens; 09-22-2019 at 04:45 PM. |
09-24-2019, 07:10 PM | #8 |
Better choice is to have charlie ny rebuild it.
09-25-2019, 01:09 PM | #9 |
Found out what I wanted to know ..34 to 48 fuel pump for caustic new fuels will work just fine..thanks much..my pump looks new and shiny brite thot maybe from china but i guess a rebuilt type without sediment bowl..sc
09-25-2019, 03:41 PM | #10 |
Fuel pumps many be similar, but the push rods vary between years, and whether the intake manifold is iron or aluminum, and the mount is correct. Any small variance can have a big effect on performance.
09-26-2019, 07:24 PM | #11 |
Don't the pumps with the glass bowl start later. Like in the 40s. I like them and run one on my 38. 36 has the standard no bowl.
An old wise/wives tale but if you replace the gasket with a cut playing card you add pressure. Maybe so... not likely. But I like the ace of spades or the 2 of diamonds. Last edited by Tinker; 09-26-2019 at 07:30 PM. |
