Old 04-30-2016, 08:44 AM   #1
leadpot
leadpot's Avatar
Default Finally Fume Free
After owning my tudor for 5 years have finally resolved my gas fume issues. Started out with dripping carb - fixed, steering wheel bracket - fixed, gas gauge - fixed. Still had fumes after these fixes & couldn't find the source after many attempts. Finally got the idea of pressurizing my tank, Got a radiator cap, drilled a small hole in it, soldered a brass tube through the cap. Hooked up to my air compressor & put 5lbs pressure in the tank, immediately heard hissing and found a small hole in the top of the tank. Now repaired and finally fume free motoring.
leadpot is offline   Reply With Quote
Old 04-30-2016, 09:02 AM   #2
burner31
burner31's Avatar
Default Re: Finally Fume Free
And that's the way it's done....
Good work LEADPOT
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 04-30-2016, 01:04 PM   #3
Dollar Bill
Dollar Bill's Avatar
Now that's ingenuity – I’ll have to remember that trick.
Glad you found it!
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 04-30-2016, 02:01 PM   #4
Big hammer
Two gaskets on the gas cap and pipe fittings from gas outlet works also! Cheaper :-)
Old 04-30-2016, 02:37 PM   #5
burner31
burner31's Avatar
The only time I get gas fumes in the cab is when my Son in-law rides with me, I think he has a four chambered stomach, the young man is worse than cattle.
Keith
Shawnee OK
'31 SW 160-B
Old 04-30-2016, 04:23 PM   #6
pgerhardt
pgerhardt's Avatar
Originally Posted by burner31 View Post
the only time i get gas fumes in the cab is when my son in-law rides with me, i think he has a four chambered stomach, the young man is worse than cattle.
lol
pgerhardt is offline   Reply With Quote
Old 04-30-2016, 04:57 PM   #7
Synchro909
Synchro909's Avatar
Only 5 lbs! You could have increased your cruising range with a little more.
Well done, McGyver.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 04-30-2016, 05:28 PM   #8
C26Pinelake
That is what we call information overload. Wayne
C26Pinelake is offline   Reply With Quote
Old 04-30-2016, 06:28 PM   #9
Hoogah
Hoogah's Avatar
You need a phaeton!
Hoogah is offline   Reply With Quote
Old 04-30-2016, 06:49 PM   #10
mshmodela
mshmodela's Avatar
Excellent fix...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 04-30-2016, 11:21 PM   #11
Mike V. Florida
Mike V. Florida's Avatar
That's tackling a problem!!!
Old 05-01-2016, 12:56 AM   #12
1ton
You mean ppphhhhhhhh hhhhhh hhaeton
1ton is offline   Reply With Quote
