Old 02-14-2012, 10:52 AM   #1
SUHRsc
SUHRsc's Avatar
Default 1939 Standard Front Splash Pan - photo?
Does anyone have a photo of a 1939 standard front splash pan...
I am missing one and just need to see what I'm looking for to compare to any that may be for sale...
Would this be the same 37-39std?
thanks
Zach
-WANTED-
Pre-War Speed Equipment
Davies or Morrison Intake Manifold
77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads
SUHRsc is offline   Reply With Quote
Old 02-14-2012, 11:17 AM   #2
Kube
Kube's Avatar
Default Re: 1939 Standard Front Splash Pan - photo?
This pan?
Old 02-14-2012, 11:22 AM   #3
SUHRsc
SUHRsc's Avatar
Kube... the panel that would attach to the front crossmember going forwards toward the radiator...
Maybe there isnt supposed to be one?
I have 2 bolts sticking down from my crossmember with nothing attached to them... assumed there should be a panel there to keep road grime off the distributor?
thanks!
-WANTED-
Old 02-14-2012, 01:11 PM   #4
DICK SPADARO
Is this what you are looking for?
dickspadaro.com
DICK SPADARO is offline   Reply With Quote
Old 02-14-2012, 01:14 PM   #5
SUHRsc
SUHRsc's Avatar
Thanks for the photo Dick,
I'm not sure.... I don't have one to compare to... is that the part that attaches to the front of the front crossmember?
If so and its yours... is it for sale?
thanks
Zach
this is what the EFV8 book shows... just trying to make sense of it... pn 81A-16550
-WANTED-
Old 02-14-2012, 01:39 PM   #6
Bruce Lancaster
Look in the chassis parts book...I'm in the '28-48, don't know where the actual '39 is.
Cooling system parts pics show what you need, though not very well...standard is 91A-8240-A...kind of murky illustration. The different deluxe one has a clearer pic that suggests mounting to those crossmember tabs. How it relates to the 16550 in the fender section is entirely unclear...from the taper shown above I'm guessing it lives between the 8240 and the grill. Need to find the '39 chassis book. I'm not at all familiar directly with these late models...
Old 02-14-2012, 01:43 PM   #7
jerry grayson
The one Dick is illustrating is the correct one for a 39 Standard.
jerry grayson is offline   Reply With Quote
Old 02-14-2012, 01:46 PM   #8
SUHRsc
SUHRsc's Avatar
thanks Bruce and Jerry
-WANTED-
Old 02-14-2012, 01:50 PM   #9
Seth Swoboda
Seth Swoboda's Avatar
What's the going rate on that part?
Old 02-14-2012, 04:15 PM   #10
Kube
Kube's Avatar
Dick depicted the other pan that is correct for your car. That, along with the engine pans were it...
Old 02-15-2012, 02:29 AM   #11
swoopNZ
MEMBER EMERITUS
I'd like one also.
Chris.NZ.
swoopNZ is offline   Reply With Quote
