09-16-2012, 04:07 PM | #1 |
Accelerator linkage stiffness
The car's always had it, but it wasn't until a friend pointed it out that I recognized the stiffness.
The pedal pushes smoothly to about 3/4 of the full travel, and then it gets a little stiff, and takes slightly more pressure to push past the stiffness and down to the floor for the last 1/4 of the full travel. It is almost like the "catch" on some older automatic transmission cars just before the kick-down is activated. The hand throttle has no stiffness, it goes to full down travel without any hitch. Is this built into the accelerator linkage, or has the car developed a hitch somewhere between the pedal and the carburetor?
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die! |
09-16-2012, 04:38 PM | #2 |
Re: Accelerator linkage stiffness
Check the battery cable from the battery to the starter. There is a little bracket that mounts on the flywheel housing to hold the cable. The bracket is a "U" shaped piece of tin with a hole. The cable can also stop the brake pedal from not going far enough to apply the brakes. Oil all of the throttle connections and the little holes in the bracket that mounts to the back of the block.
Make sure the battery cable is the correct length and there might be some rub marks on your existing cable. In SD we calls these Indian signs.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
09-16-2012, 04:40 PM | #3 |
Be sure to lets us know what you find.
Thanks
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. Last edited by sturgis 39; 09-16-2012 at 04:42 PM. Reason: added thanks |
09-16-2012, 04:51 PM | #4 |
It could simply be a bend in the unit that increases in misalignment the further you push it down. If the throttle lever feels smooth though it's travel then I'd bet it's only providing 3/4 throttle.
http://www.abarnyard.com/ |
09-17-2012, 01:17 AM | #5 |
Have the floorboards sagged? That can happen and make the pedals rub on them. You probably checked that already though.
09-17-2012, 01:53 AM | #6 | |
Excellent response to this problem. I bent my throttle pedal while pulling the engine one time. It got held up on the firewall. I had to bend it to clear the floor boards.
09-17-2012, 10:17 AM | #7 |
Have you oiled the linkage recently? Check the lubrication chart. There are a couple of places near the block designed for oil. I can't explain why the hand throttle works well.
Charlie Stephens |
09-17-2012, 10:45 AM | #8 | |
We have not heard from Roccaas except for the original post. He could be driving his Model"A" to attend the noon performance at the neighborhood strip bar. I know that is where I would be if all off the fat ladies in town did not have it shut down.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. Last edited by sturgis 39; 09-17-2012 at 10:53 AM. Reason: added strip bar |
09-17-2012, 12:25 PM | #9 |
Does it return under spring-pressure, or do you have to lift the pedal with the edge of your shoe ?
09-17-2012, 12:45 PM | #10 | |
Charlie Stephens |
09-17-2012, 12:45 PM | #11 |
Its the secondaries kicking in
