Old 02-29-2016, 12:11 PM   #1
55 dude
55 dude's Avatar
Default 33-34 light duty panel
i have found some pieces to what i think are 33-34 panel. i would like to talk to someone who has one. thanks
55 dude is offline   Reply With Quote
Old 03-01-2016, 02:27 AM   #2
55 dude
55 dude's Avatar
Default Re: 33-34 light duty panel
bttt!
Old 03-01-2016, 06:05 AM   #3
Cool 33
Cool 33's Avatar
Could be. The wheel well location could help to identify. If it is more off center to wards the front, then probably 32. Closer to center then 33-34. The door is for something more late 40's and probably not Ford.
Cool 33 is offline   Reply With Quote
Old 03-01-2016, 09:00 AM   #4
Fordors
As mentioned the wheel well location is different, '32 is 106" WB and '33-'34 are 112", but I believe the '32 looks more centered. The upper side panel reveal lines are different between the two also, with a radius that matches the one shown in your photo at the front and rear on the '32. If there is a like radius at both ends on the upper reveal line then it's '32, and if the rear is radiused and the front square you have '33-'34 quarters. The door shown is not Ford.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery.
Fordors is offline   Reply With Quote
Old 03-02-2016, 08:22 AM   #5
55 dude
55 dude's Avatar
thanks!
Old 03-07-2016, 01:38 AM   #6
55 dude
55 dude's Avatar
new pictures say it's 33/34! need id on fender.
Old 03-07-2016, 02:18 AM   #7
deuce lover
deuce lover's Avatar
Post a pic of the front lower section of the fender where it sits on the frame.There should be a small raised area near where the grill shell sits.If so its a 33-34 commercial.The dash is 33-34 commercial.
Old 03-07-2016, 09:18 PM   #8
55 dude
55 dude's Avatar
so if no raised area it's a 32?
Old 03-07-2016, 10:00 PM   #9
deuce lover
Most likely yes.A mounting hole for the front frame horn is in the slope next to where it flattens out .Maybe someone can chime in and post a pic.
