08-17-2012, 07:19 PM | #1 |
How fast can an 80 year old A engine go?
08-17-2012, 08:55 PM | #2 |
Re: How fast can an 80 year old A engine go?
Musta had the spark all the way down
08-18-2012, 02:48 AM | #3 |
Dyno'd at 360hp with 9lbs of boost.
08-18-2012, 07:14 AM | #4 |
Congrats to the whole team. What a great accomplishment!!
08-18-2012, 08:17 AM | #5 |
It didn't sound like a Model A, they must have had the wrong muffler. Also the steering seemed a little loose once he got it over 200 MPH.
WOW, what a performance. I'll have a new answer for those who ask, "Hey mister, how fast will it go"! |
08-18-2012, 08:19 AM | #6 |
Seems from video that he shifts alot ... What is aprox. Quick Change ratio at those speeds? Just wondered. Last edited by Benson; 08-20-2012 at 04:41 AM. |
08-18-2012, 08:31 AM | #7 |
I would of liked to see the ENGINE ....or atleast a picture of it...
08-18-2012, 08:44 AM | #8 |
Not your father's Model A engine!!
08-18-2012, 09:14 AM | #9 |
Why was a Model A block used ?
Marc |
08-18-2012, 11:18 AM | #10 |
Milton - Waaay COOL!! Thanks for sharing, and congratulations all around.......that was a SWEET sounding "A".......
WARM REGARDS, MARCUS |
08-18-2012, 01:17 PM | #11 |
Thank you the engine picture... it seem to be setup backwards ???? the back of the engine is in front facing the nose???? All from a original Model A block...
08-18-2012, 02:19 PM | #12 |
There are different classes and a class for Model a engines. I suppose he wanted to see if he could beat the record with a model a block
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
08-18-2012, 04:04 PM | #13 |
A-mazing! Now I wanna see it done with model A brakes instead of a 'chute.
08-18-2012, 07:37 PM | #14 | |
Benson The item displayed in your avatar looks interesting? Is it a super charger? Thanks
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
08-18-2012, 08:38 PM | #15 |
Just noticed that, my guess is a Robert Roof intake with two Winfields. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
08-18-2012, 09:40 PM | #16 |
It appears to have a turbo charger connected to the header. It also has some type dual over head cam head.
08-18-2012, 09:53 PM | #17 |
Marc; The car runs in a Vintage engine class, you have to run a factory stock block, this particular car runs in the streamliner class, other popular car classes include Lakester (belly tank, openwheel) roadster and coupe. I was at lunch today with the guy that just bettered his vintage Lakester record to 196.00 mph. Modern 4 bangers run over 300,with one car trying to better 350. Callcoy
Steve - Santa Rosa |
08-18-2012, 10:03 PM | #18 | |
Bill Kenz's streamliner 777 in the 50's had two flathead V8's attached to the front wheels and later a third Flathead was added driving the rear wheels. This Friday I was talking with Cal Kennedy who drove one of the three push "cars" (actually he drove the 31 Model A with two flatheads, one in front and one in rear that went 140 MPH at Bonneville in 1949. Bill Kenz used the truck as a pusher after the streamliner was built. Anyway Cal said that one of the problems they had after adding the third engine was that over 230 or so the airflow lifted the rearend enough for the rear wheels on the streamliner to lose traction. Mr. Kenz made modifactions to the bottom of the body to get more downward force to keep the wheels on the salt, so the engine did not over rev. Cal Kennedy said that there was a removable panel on the rear used to change the Quick Change gears which was removed and modified to increase downward force on the rear wheels. 777 Broke 200 in 1950 with two flathead engines and by 1957 was turning over 270 MPH with the 3 engine configuration. http://www.chromjuwelen.com/de/netwo...onneville.html Last edited by Benson; 08-19-2012 at 06:56 AM. Reason: errors- added info also |
08-18-2012, 10:18 PM | #19 |
Ahyone know what the record is for a Model A engine that is still a flathead? Quite a bit slower I'm sure, but still curious.
08-18-2012, 10:18 PM | #20 |
Looks like a turbo to me with the exhaust tubes all going into the turbo ... I was told it makes 360 horse power with 9 lbs of boost. A fellow at coffee yesterday who was there at Bonneville said they were turning 6600 RPM going through the timing trap.
Quite sure there are some folks out there that know alot more information than this ... Last edited by Benson; 08-19-2012 at 07:02 AM. |
