04-30-2014, 07:26 AM | #1 |
Brakes..has anyone tried?
I adjusted the brakes on the 31 coupe the Les Andrews way. Rear work first. Car stops like it should.....just wondering
Has anyone ever set the brakes where the Front start to work first? |
04-30-2014, 08:50 AM | #2 |
Re: Brakes..has anyone tried?
yes i have & if done correctly , in good cond. they are great .
V4f |
04-30-2014, 09:37 AM | #3 |
I have my front brakes working first, been that way since I got the car restored in 2000 and 20,000 miles. They work very well that way.
04-30-2014, 10:40 AM | #4 |
Thanks. That's what I wanted to know.
04-30-2014, 01:41 PM | #5 |
Jist adjust the rods to where ALL the brakes apply at the SAME time!!!-----I'M THROUGH, coffee's READY!!-----Bill W.
04-30-2014, 02:00 PM | #6 |
04-30-2014, 02:24 PM | #7 | |
I'm with you on your thinking. However, I was told that Ford did say to have the rear come on slightly ahead of front brakes. Personally, I do as most here subscribe to. I think that I understand Fords thinking/practice of rears coming on first. |
04-30-2014, 02:33 PM | #8 |
I believe that Ford suggested that rears grab first because almost all of the roads were gravel, dirt or mud. I've driven a Model "A" on gravel roads quite a bit and when the fronts lock first you have less control over which way the car is going to go than when the rears lock first. You don't want the fronts to lock just before starting over one of those forest service flat bridges at any speed. (Yes, I was a bit foolish in my youth - but I did pretty good at "dirt tracking" in a Model "A".) Remember - almost all vehicles except Cord were rear wheel drive back then and with gravel roads you want oversteer, not understeer..everyone was used to slightly twitchy handling.
04-30-2014, 03:10 PM | #9 |
IMHO Ford designed the rears to lock first with more pressure on the rear shoes due to the action of longer levers in a pulling action as opposed to the fronts where there is a pushing pin action with shorter levers.
Pete |
04-30-2014, 03:19 PM | #10 |
Randy,
The proportioning valve does NOT cause the front brakes to come on first. It ONLY controls the total pressure that can be applied to the REAR brakes, so they don't lock up & come, "ASS AROUND" Chief "ASSED AROUND" 3 times, in his '62 Ford short bed P.U. & later, added a proportioning valve, problem solved. Before the valves were available, he carried 2 bags of sand in the rear of the box, to prevent lock-up & SCREEEEEEEEEECHING!---Bill W.
04-30-2014, 03:36 PM | #11 |
I think Vermontboy nailed it!
04-30-2014, 06:24 PM | #12 | |
Not quite sure exactly what your point is Bill, but it seems you've taken what I said out of context somehow. The following is a direct quote from the installation instructions of a Summit Racing adjustable proportioning valve: "Front-to-rear brake balance should be adjusted so that the front wheels lockup slightly before the rear wheels". Other than my use of "grab" where they used "lockup" did we not say the same thing?? |
04-30-2014, 08:29 PM | #13 |
As I discovered while riding my Lambretta motor scooter back in '62, and just before I hit the lady who pulled out in front of me, the front brakes have the most braking power. Dynamics determine that. On modern cars the front shoes are therefore larger than the back, and wear out later. I'm just about to adjust the brakes on my '29 pickup and was wondering the same thing. Why does he specify that the back brakes lock up first? On the surface it doesn't make sense. Before I adjust them I'll take the drums off to see what kind of condition they're in and maybe determine the answer to this puzzle.
Ned
Retired civil engineer. Winters in Phoenix, summers in Ipswich, Mass. and North Dakota. '29 closed cab pickup- Excellent AZ truck. '29 roadster- Owned for 21 years but now sold. '28 CC pickup- My first car in Andover, MA back in '62- '63. |
04-30-2014, 09:26 PM | #14 | |
