Old 03-19-2024, 08:38 PM   #1
Vanspeed
Vanspeed's Avatar
Default Spare tire bracket 28-29
I am installing steel fenders on a customers RPU that had glass fenders. I found a pic that says the point on the triangle bracket should be pointed towards the rear. This was opposite. It also has a slight dish in it where it mounts to the arm. No L or R designation on it. What does a factory 28-29 triangle bracket look like installed and does it in fact point to the rear like this photo?
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 03-19-2024, 08:56 PM   #2
Marshall V. Daut
Default Re: Spare tire bracket 28-29
That plate is angled forward on 1930-31 Model A's, but is straight up and down on 1928-29's with side wells. The point of the plate is at the bottom. Make sure you have the correct side arm, as they are different between the '28-29 and '30-31 Model A's.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 03-20-2024, 11:48 AM   #3
Marshall V. Daut
Maybe these comparison photos will help you determine which side mount arm and plate you have. The almost-assembled car shown is a 1929 Murray Town Sedan with dual side mounts. Note the plate orientation, as well as the length and shape of the two arms.
Marshall
Old 03-20-2024, 11:56 AM   #4
Marshall V. Daut
By the way, if you have the incorrect '30-31 side arm, mount and plate instead of what you need for your '28-29 Model A, I have a complete new set-up that has never been installed. See the want ads from two weeks ago. Less than 1/2 price from ordering the same thing. Shipping cost only added.
Marshall
File Type: jpg Daut_1928-29 side mount bracket_1_resized.jpg (85.5 KB, 4 views)
Old 03-20-2024, 12:31 PM   #5
Vanspeed
Vanspeed's Avatar
Looks like the customer has the wrong triangle plate but correct arm. Is this a ‘30-‘31 plate?
Old 03-20-2024, 01:44 PM   #6
Randy in ca
Randy in ca's Avatar
Can't tell for sure from you picture but think you have a 1930-31 mounting plate. Most obvious difference is the angle of the center slot.
File Type: jpg 1928-29 Front Spare Mounting Plate.jpg (176.1 KB, 76 views)
Randy in ca is offline   Reply With Quote
Old 03-20-2024, 04:32 PM   #7
Marshall V. Daut
Good news for the poster if only the plate is wrong on his side mount setup. He can order just the plate needed from Snyder's @ $10.95 + S & H:
https://www.snydersantiqueauto.com/p...3875&cat=41742
Because the '28-29 plate's slot is vertical, it can be used on either side, unlike the '30-31 plates, whose slot is angled, meaning there is a left and right plate.
Marshall
Old 03-20-2024, 05:11 PM   #8
Vanspeed
Vanspeed's Avatar
Thanks for the link! I will be ordering the correct plate for it.
Marshall
Old 03-21-2024, 10:55 AM   #9
katy
katy's Avatar
Marshall V. Daut's photo, (post #2) show the bottom end of the support bracket as being vertical, and his photos (post 3) show it as being horizontal. Are they from different years? Different applications?
