Old 06-11-2011, 12:49 PM   #1
saints
saints's Avatar
Default cam and oil pump question on a 8ba
Ok how do I get the cam out.... pulled yje back cover and theres 2 gears do I have to pull one.....also the oil pump isnt budging so theres got to be a trick to getting it out of there
FLATHEAD ADDICT
saints is offline   Reply With Quote
Old 06-11-2011, 02:09 PM   #2
saints
saints's Avatar
Default Re: cam and oil pump question on a 8ba
ok i got the cam out....not sure the right way but its out.....the oil pump still wont budge
FLATHEAD ADDICT
Old 06-11-2011, 04:02 PM   #3
flatjack9
flatjack9's Avatar
Try twisting and pulling. Some can be stuck pretty tight.
Old 06-11-2011, 04:14 PM   #4
Zeke...PA
Zeke...PA's Avatar
Be careful I broke the ear off mine prying and twisting. Zeke
Only problem with retirement is never a day off
Zeke...PA is offline   Reply With Quote
Old 06-11-2011, 04:18 PM   #5
saints
saints's Avatar
thanks I hit it a couple of times and it didnt budge so I wanted to seel advice before I started yanking on it
FLATHEAD ADDICT
Old 06-11-2011, 04:38 PM   #6
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Don't try to pry it out. I take a big pipe wrench, grab the pump (where the gears are) and maybe an extention to put on the pipe wrench, twist the pump back and forth, squirt some weasel pi-- around the bottom, when you can twist it easy try prying it up a little with a pinch bar while twisting. It will come. Walt
Old 06-11-2011, 05:24 PM   #7
Ol' Ron
Ol' Ron's Avatar
Use some of the 50-50 mix as well, this stuff really works.
Old 06-11-2011, 08:25 PM   #8
saints
saints's Avatar
yep ron I have a batch mixed always....thats how I got this flathead tore down.....wish I could get a 50 gallon drum of the 50/50 mix and soak the hole engine
thanks for the advice Ill take a crack at it tomorrow as Im wore out from scrubbing flathead valve assembly's in the parts washer
FLATHEAD ADDICT
Old 06-12-2011, 08:00 AM   #9
saints
saints's Avatar
hey does the large gear at the back come off or can I leave it on during the cleaning of the block
FLATHEAD ADDICT
Old 06-12-2011, 10:42 AM   #10
Henry/Kokomo
Henry/Kokomo's Avatar
I'd take the idler gear out to make cleaning easier. There's a tapped hole in the stub shaft it rotates on. Attach a slide hammer to the pin and knock it out. Very simple. JMHO. Good luck.
Henry/Kokomo is offline   Reply With Quote
Old 06-14-2011, 01:44 PM   #11
saints
saints's Avatar
Ok thanks guys I now have the cam out and pulled the oil pump(wow did it have a bunch of crap in it when I pulled it) and tonight Im pulling the gear and off to the hot tank it goes.....thanks again for the insight
FLATHEAD ADDICT
Old 06-14-2011, 03:48 PM   #12
52merc
52merc's Avatar
ron whats the 50/50 mix
52merc is offline   Reply With Quote
Old 06-14-2011, 04:13 PM   #13
Joe AZ
Joe AZ's Avatar
I believe Ron's refering to a 50/50 mix of automatic transmission fluid and acetone. Seems to be the hot set-up for freeing up frozen parts.
Joe
Joe AZ is offline   Reply With Quote
Old 06-14-2011, 05:02 PM   #14
phartman
phartman's Avatar
Aw, man, is that all you were talking about? I was hoping the formula somehow involved wild animal urine as the secret ingredient....What a disappointment.
phartman is offline   Reply With Quote
Old 06-14-2011, 07:52 PM   #15
saints
saints's Avatar
not that exotic but it does the trick.....and if you use evapo rust
FLATHEAD ADDICT
Old 06-15-2011, 06:15 AM   #16
Mac VP
Mac VP's Avatar
Don't forget to remove the oil galley plug in the front behind the timing gear. It's a good idea to use a long narrow brush (ie rifle barrel brush) to clean out the tube. DO NOT FORGET to replace the plug on the rebuild.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 06-15-2011, 09:17 AM   #17
flatjack9
flatjack9's Avatar
The only way to properly clean this passage is to remove the fuel pump pushrod bushing so you can get a clear shot through the tube.
