11-13-2012, 12:33 PM | #1 |
New style oil seal require a jiffy sleeve?
This may have already been covered but I didn't find it on a search. I am installing the new style solid rubber front oil seal on 39 59A motor rebuild. The mating surface on the crank pulley has a "spiral" machined in the surface which apparently is designed to push oil towards the pan. Is that a problem? Should there be a smooth surfaced sleeve on the crank pulley?
bd in Ky |
11-13-2012, 01:13 PM | #2 |
Re: New style oil seal require a jiffy sleeve?
i used a smooth sleve sold buy REDS HEADERS YOU WIILL NEED TO MACHINE PULLEY
FOR 59-A |
11-13-2012, 01:16 PM | #3 |
It's known as a speedy sleeve. Only thread I found
https://www.fordbarn.com/forum/showth...=speedy+sleeve |
11-13-2012, 01:19 PM | #4 |
