07-01-2015, 04:04 PM | #1 |
Correct luggage rack - I hope!
My goal with my 29 tudor is to as close as possible return it to the way it might have looked in 1929. As part of that I am both removing all the "bling" added to it probably during its last restoration. and correcting any mistakes I find. The car came with a chrome with woodgrain slats repop luggage rack (on the left in the image below), which might look good on a deluxe roadster, but did not look like it belonged on a 29 tudor - which was basic transportation back then. I found a black luggage rack (on the right below) that looked more at home. But before I disassemble it to restore it and transfer over the mounting brackets to allow it to sit behind my spare, is this truly a "standard" luggage rack that would have been found on a non deluxe model A sedan?
07-01-2015, 04:29 PM | #2 |
Re: Correct luggage rack - I hope!
When you remove the white walls you may want to advertise them on the barn to trade rather than buy new ones. Wayne
07-01-2015, 05:16 PM | #3 |
What you have are 2 De Luxe racks only one is painted black.
See pictures for standard one |
07-01-2015, 05:18 PM | #4 |
Joop you selling that gorgeous rack???
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
07-01-2015, 05:30 PM | #5 |
Thanks for the info. I suspected as much when I spotted some chrome in a spot that did not get sprayed. I am guessing that this might be an original deluxe rack with steel slats while the other is definitely a repop with wood slats rather than steel. the distance between the two mounting points on the deluxe luggage rack brackets (both the repop and the other one I found is 4 1/2". Wondering if my extended brackets will work with a "standard" rack.
I guess what I'll do is clean up and use the black deluxe rack for now, while I (Now that I know what I am looking for - THANKS!) keep my eyes out for a "standard" one. |
07-01-2015, 05:31 PM | #6 |
It's the one VARCO sells http://www.varcoinc.com/ |
07-01-2015, 08:12 PM | #7 |
Yeah That's it. I'll put it on my "when I have the money" list!
07-01-2015, 08:16 PM | #8 | |
07-01-2015, 09:04 PM | #9 |
Does anyone have a pair of the brackets and arms. I'm looking for a set. I have the rack but no hardware. Varco doesn't answer the phone!!??
John Poole |
07-01-2015, 10:52 PM | #10 |
There were many types of rear carriers put on Model A's when new.
See all the adverts in ''Unauthorised Accessories'' [ Fahnestock] . Probably more of the simple steel bar & bent frame types went on Sedans than the pressed steel ones sold by Dealers. I agree, those deluxe chrome ones do not look right on a standard Sedan My Tudor had one of these steel bar ones put on when new . |
07-03-2015, 09:09 AM | #11 |
Here's mine:
The Ford Barn > General Discussion > Model A (1928-31) > Luggage Rack Behind Spare on 28 Phaeton https://www.fordbarn.com/forum/attach...8&d=1407768603 |
07-03-2015, 09:24 AM | #12 |
There were a lot of racks being sold back when the Model A came out. Visit some swap meets you should find one that suits your needs.
07-03-2015, 09:49 AM | #13 |
The authentic 1929 rack was introduced by Ford in the June 1929 Service Bulletins and a photo is part of the article. By the way it cost the dealer $9 and suggested installation charge was $1. It was assigned part number A-18075.
07-03-2015, 03:10 PM | #14 | |
BTW notice the full width (front?) bumper. Was that common for 29 sedans? |
07-03-2015, 03:46 PM | #15 |
Are you replacing the white walls ? Wayne
07-03-2015, 04:37 PM | #16 |
07-04-2015, 01:02 AM | #17 | |
With that pressed steel rack in the SB's, there may have been different mounting brackets, but I believe it would not fit if there was a rear mounted spare? Just think, the Dealer sells the rack & gets to sell a new fender with well also. I know a car here with one & the owner had to make different brackets for it to fit with the rear spare wheel. |
07-04-2015, 07:58 AM | #18 | |
As far as the "extended" rear bumper is concerned...Ford introduced this idea in the March 1928 Ford Service Bulletin and is also stated as such in the Parts Price Lists in the bumper sections. It is refered to in the Ford records as the "Rear Bumper (Cross Bar Type)". With all respect to Tudortomnz's statement, I do not think it mattered weather the car had a side mount or not as the bulletin information does not specifically say that BUT I could be wrong on that assumtion...who knows? If the owner desired a rear bumper of this type, the change over was easily made. Pluck |
07-04-2015, 08:50 AM | #19 |
I was at a show in Michigan last Friday and while in for dinner some low lifer stole all my dust covers ! They were originals and not the cheap reproductions ! Wayne
07-04-2015, 11:23 AM | #20 |
C26, that is terrible. That would never cross my mind. Awful.
