03-10-2013, 05:29 PM | #1 |
Horn Question
I need some electrical help. When I blow my horn, the horn button heats up. Is that normal. Also I have to rev up the engine to get the horn to blow without sounding like it's dying. Is this caused from a bad ground?
Jamie Crosson 1929 Tudor Looking for an Original 888 Key |
03-10-2013, 05:48 PM | #2 |
Re: Horn Question
almost certainly. id remove the horn rod and rebuild it. lucky you have a sedan cause a coupe or pickup isnt so easy to get apart
03-10-2013, 06:09 PM | #3 |
Re: Horn Question
It seems to be normal for the repro horn button, but not for the originals.
03-10-2013, 06:33 PM | #4 |
Re: Horn Question
try removing the back cover on the horn and put a couple drops of ATF on the front and back of the armature shafts
you can also ground the blue/yellow wire from the horn to bypass the horn button Last edited by Mitch//pa; 03-10-2013 at 06:43 PM. |
03-10-2013, 10:28 PM | #5 |
Re: Horn Question
Mike |
