Old 06-01-2016, 04:55 PM   #1
1ton
Default T radiator A chassis
I have a '27 roadster body just sitting around. Recently acquired a running '30 chassis. I'm thinking about mating the two together. The plan is to keep the chassis all original, mechanical brakes included, and use the original T hood and radiator shroud. My question is about cooling. Since I don't have a radiator and would have to buy a new one, would the smaller radiator cool the A engine enough or should I plan on a '28 '29 radiator and shroud instead.
1ton is offline   Reply With Quote
Old 06-01-2016, 09:49 PM   #2
jackdaron
Default Re: T radiator A chassis
There are a few Model T's with Model A engines in them.They seem to run fine.
jackdaron is offline   Reply With Quote
Old 06-04-2016, 05:09 PM   #3
dumb person
dumb person's Avatar
The hood of a T is slightly shorter than an A if i remember correctly.. So you might have to move the rad' back or get creative. The T rad' is slightly wider too so moving it back an inch or 2 should allow it to sit on the frame rails nicely.
Disclaimer: this info' is based on old memories and may not be the most definitive guide ever.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
