12-11-2011, 04:14 PM | #1 |
engine stand
Just fired up O'Ron's and Walt Dupont engine on my new engine stand. Got to pretty up the stand with some head lights and tail light but it works good. I built it high so I don't have to bend over. Hope the these 4 pic come out. Walt
12-11-2011, 04:52 PM | #2 |
Re: engine stand
Very nice! The ancient battery charger is a nice touch too!!
Lonnie |
12-11-2011, 04:52 PM | #3 |
Re: engine stand
i like your old Sun battery charger, i used to have one, i sold it at a swap because i did not need it it was only for 6 volt batteries. now i have a 6 volt battery
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
12-11-2011, 05:57 PM | #4 |
Re: engine stand
That's a dandy engine stand. Looks like it has pretty much everything there to make her run. Nice job.
12-11-2011, 06:16 PM | #5 |
Re: engine stand
I like your 3 speed electric fan. Has its own built in fan shroud, too!
Alan |
12-11-2011, 06:20 PM | #6 |
Re: engine stand
The stand looks good. Fun to be able to fire up a new build. Share with us the proper way to run a new engine on a stand to "seat" the rings. I have a fresh 8ba on my stand and have only run it a total of 30 minutes so far. John |
12-11-2011, 06:50 PM | #7 |
Re: engine stand
It look's good in person, and that flathead sounds sweet. Someone will have a big grin on their face
12-11-2011, 08:20 PM | #8 |
Re: engine stand
Walt,
As usual nothing short of excellence. Looks great and very sturdy, can only imagine how many engines will fire for the first time on it..... |
12-11-2011, 08:30 PM | #9 |
Re: engine stand
Hey Walt,
Should I bring mine back and put it on there for the break in period! Rick |
12-11-2011, 08:32 PM | #10 |
Re: engine stand
very nice start up stand....and well made!
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
12-11-2011, 08:36 PM | #11 |
Re: engine stand
looks good, what size stock did you use?
12-11-2011, 08:59 PM | #12 |
Re: engine stand
Thanks guys, the Sun batt charger come from an old Sun dist machine, the shop went out of busness in 61, it's a 6-12 volt charger. I've had it for over 50 yr's. I wish I had the dist machine. You guys are going to worry yourself to death about seating rings on a stand. All I did for 50 yr's was work in auto machine shops, I've buit 100's of engines fired up so many I cain't remember. I've never had one that the rings didn't seat. The idea is don't let a new engine slow idle. When you first start it if the oil pressure is good speed right up to 15-1800 and let it sing for 15-20 min. jazz the throttle every now and then, keep an eye on the temp. I've built many industral engines for cement trucks, welders, every staionary thing you can think of. How many of these engines do you think went down the road to seat the rings? People will build or get a new engine for a classic car, they fire it up before the car is finished, thay'll idle it down to see how slow it will run, a few days will go by and a friend comes to see the car, listen to my engine, you cain't even see the fan turn, this goes on for a year, buy the time they get to go for a ride the plug are all black as a boot and gas has washed down the pistons and rings. NOW THAT'S HARD ON AN ENGINE, DON'T LET A NEW ENGINE RUN SLOW. Merry Christmas. Walt
12-11-2011, 09:06 PM | #13 |
Re: engine stand
12-11-2011, 09:08 PM | #14 |
Re: engine stand
12-11-2011, 11:17 PM | #15 |
Re: engine stand
Hi Walt; Great job as always. After the head and tail lights maybe add a tach and some fuzzy dice. Looks to me like you might have some serious time in plumbing. Merry Christmas to you and Rockie, Craig.
" When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much he had learned " Mark Twain. |
12-11-2011, 11:27 PM | #16 |
Re: engine stand
Walt, looks great. What kind of distributor are you using with this engine? Ed
12-11-2011, 11:52 PM | #17 |
Re: engine stand
Walt, your too much that was hularious, fire it up and let sing. You're killing me on this end lol, nice to have so much knowledge all in on place.
Peter |
12-12-2011, 08:17 AM | #18 |
Re: engine stand
