Old 04-04-2011, 06:39 PM   #1
Roger/Sacramento
Roger/Sacramento's Avatar
Default Three carbs for the '41 Pickup
When practical I like to make parts for the project. I cut out from walnut wood some plates for under the carbs. The linkage drops were carved out of aluminum stock. Brass rods were made up for the linkage connectors. The coil will be mounted on the front. I had a lot of help from Stromberg 81 (Duane). He really understands how Strombergs work and is very particular in the assembly. I could have put the carbs together myself but let Duane do it and I know they are done right because of it. I highly recommend him for anybody that wants work done right.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 04-05-2011, 06:58 AM   #2
jdl
jdl's Avatar
Send a message via ICQ to jdl
Default Re: Three carbs for the '41 Pickup
Beautiful work Roger.
jdl is offline   Reply With Quote
Old 04-05-2011, 07:02 AM   #3
TomT/Williamsburg
TomT/Williamsburg's Avatar
Great looking setup!
TomT/Williamsburg is offline   Reply With Quote
Old 04-05-2011, 11:24 AM   #4
stromberg81
stromberg81's Avatar
Roger, those filters came out beautiful..I know that the throttle plates open and close together..Yes, the setup look GREAT..
Duane..
ps..Thanks for the acknowledgement..
..Commitment is a 100%..
stromberg81 is offline   Reply With Quote
Old 04-10-2011, 01:49 PM   #5
Roger/Sacramento
There has been interest in where I got the banjo fittings. http://blundellspeed.com/index.html
Old 04-16-2011, 01:28 PM   #6
Roger/Sacramento
Just did linkage for the carb to firewall. Some aluminum round stock was drilled and tapped. A slice along the backside allows the ball on the carb linkage to slide to the bottom of the tap. A stainless button head bolt is attached to keep the round stock in place. A brass rod is used to connect the two ends.
