03-20-2012, 08:24 PM | #1 |
Rear Main Oil Leak
The rear main leaks pretty bad from the weep hole in the bottom of the fly wheel case. It has become untolerable to drive far. Is there any way to fix this short of pulling the engine and spending a lot of $$ ? Otherwise engine runs fine. Thoughts?
03-20-2012, 08:36 PM | #2 |
Re: Rear Main Oil Leak
Leaks can come from various places and leak out the hole in the bell housing. Check to see exactly where the leak is coming from.
http://antiqueenginerebuilding.com/REARMAINLEAK.html Mine had a bad leak and I was embarrassed to park anywhere someone would see how bad it was. Mine ended up being a problem with the previous install of the rear main as well as too much clearance in the bearing. I adjusted all the mains and rods, installed the real metal seal correctly and no more leaks
"Betsy doesn't leak oil - she just marks her spot" |
03-20-2012, 10:43 PM | #3 |
Also make sure that crankcase pressure isn't forcing the oil out the rear main drain back tube. You do this by making sure your oil fill tube's cap isn't pushed on to tight and can allow the case to breath properly. The pressure pushes the oil from the pan, up the tube, and out the rear main seal if not vented properly.
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
03-21-2012, 07:12 AM | #4 |
My leak was caused by a blockage in the oil drain pasage in the main bearing block.
03-21-2012, 08:37 AM | #5 |
my leak was caused by my K&N filter . not enuff breathing . installed pcv valve .......
V4f |
03-21-2012, 09:20 AM | #6 |
Ray White |
03-21-2012, 09:35 AM | #7 |
The article referenced by Greg is an excellent place to start. Until then several online vendors sell what we call a diaper to help control the leaking until you can sort it out. Spend some time and search through some of the older postings on rear main oil leaks and you will find a wealth of information.
Rear Main Diaper
Oklahoma City Model A Restorers Group. |
03-21-2012, 07:19 PM | #8 |
My leak was the missing gasket between the flywheel housing and block..at the end of the cam.
03-21-2012, 08:32 PM | #9 |
Over filling the oil pan can cause a leak. use 4 1/2 gt. Bill
03-21-2012, 08:44 PM | #10 |
The drain tube for my Rear Main was seated too deep and bottomed out, obscuring the opening. It really was an easy fix.
Style beats speed any day, and with a lot fewer tickets. |
