04-20-2012, 07:44 AM | #1 |
57 T Bird question?? From Bubbas
Although i usually hang out on the earlier forums , i have a customer with a interesting issue. Its a really nice 57 T Bird with the 312 engine and a factory air cleaner.
The air cleaner is factory but the air filter element isnt. It appears that the filter element is quite a bit shorter in height than it should be as the upper part of the air cleaner only allows a small air gap for air to travel thru when installed . Maybe 3/8 of a inch or less!!! Engine runs rich and runs better when air cleaner is removed. Anyone know the correct height for the air filter element??? Thanks in advance |
04-20-2012, 08:47 AM | #2 |
Re: 57 T Bird question?? From Bubbas
Bubba, those air filters are available at any early bird parts store, email me if you need a store location. There should not be any air gap, the filter should seal top and bottom. It sounds like he has two issues a filter with to much air gap that would not cause the engine to run rich. A carb, vacuum or timing problem. P/S thanks for the work you did on my flathead distributors. Frank
04-20-2012, 11:36 AM | #3 |
The air filter unit on my '57 Bird is an original stock unit... The filter is a 'PEROLATOR' APF 80... 2/3" x 13-3/8"...
Bill.... 36 5 win cpe |
04-20-2012, 07:26 PM | #4 |
Mine measures 3.56 inch high.
04-20-2012, 09:35 PM | #5 | |
04-20-2012, 09:36 PM | #6 |
