Old 09-12-2011, 04:52 PM   #1
bobbooth
bobbooth's Avatar
Default 34 garnish moldings?
I have got the chance to buy some 4 door front garnish moldings and am I correct in thinking that they will fit 5 window doors? the measurements are as follows They are 34.25 inches long and 16 inches high on the outside, The inside, or the opening measures 32.5 long and 13 inches high. any thoughts on this.thanks
bobbooth is offline   Reply With Quote
Old 09-12-2011, 05:02 PM   #2
gearhead1952
gearhead1952's Avatar
Default Re: 34 garnish moldings?
Yes they will fit a 5w. You will need to shorten the rear most portion by about 3/4 inch. If you do the shortening in the corner they will be easier to do.
gearhead1952 is offline   Reply With Quote
Old 09-13-2011, 01:53 AM   #3
bobbooth
bobbooth's Avatar
Ok thanks for that,
so the sizes sound correct for a 4door front and not a 2door sedan?
Old 09-13-2011, 07:48 AM   #4
Bob/Pa
Bob/Pa's Avatar
my 34, 5 window coupe's driver side measures 27" long and14.5" high.
Bob/Pa is offline   Reply With Quote
Old 09-13-2011, 09:15 AM   #5
ls1nova71
ls1nova71's Avatar
This is about what my '34 fordor garnish moldings measure. The 34" ones have to be from a Tudor.
ls1nova71 is offline   Reply With Quote
Old 09-13-2011, 09:56 AM   #6
bobbooth
bobbooth's Avatar
Thanks for the information guys, Guess I better not buy them then, could have proved a bit costly especially with the shipping
Well if anybody is looking for some Tudor ones then they are on the auction site and this is the item number 330612641232
Old 09-13-2011, 10:03 AM   #7
gearhead1952
I failed to look at the measurements and yeah they do seem too long for the short 4 dr doors. If you find some from a 4 door you can make them work on a 5w since 5w stuff can be pricey.
Old 09-13-2011, 10:17 AM   #8
bobbooth
bobbooth's Avatar
No probs , thanks for you time , and yes i am beginning to notice..
