Old 12-06-2014, 09:14 AM   #1
Brendan
Brendan's Avatar
Default Ford Ranger Trasmission
Help! what kind of oil do I put into my 2003 Ranger 5 speed? please don't shoot me down for asking this question
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 12-06-2014, 09:52 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Ford Ranger Trasmission
It would most likely be Mercon V if you have the M5OD transmission. I have a shop manual for my 2000 Ranger so I'll have to check that to confirm what it states for the M5OD 5-speed.
Old 12-06-2014, 10:17 AM   #3
john in illinois
john in illinois's Avatar
I have a 2001 ranger 5 speed and I use Ford spec ATF.
John
john in illinois is offline   Reply With Quote
Old 12-06-2014, 10:29 AM   #4
rotorwrench
From information I've found, it indicates that after FoMoCo developed the Mercon V synthetic and eventually made it reverse compatible to Mercon III. They then revoked license to produce Mercon III as obsolete. I think the older spec is still available since it was compatible with a later Dextron spec.
Old 12-06-2014, 11:02 AM   #5
Ol' Ron
Ol' Ron's Avatar
I had a 95 Ranger 4 banger and used ATF. Not sure if it waz right but it worked. Nice trans>
Old 12-06-2014, 12:09 PM   #6
Fordestes
I have been using 10 w 30 engine oil in my ranger 5 speed t-5 in my pinto havn't had any problem , will this cause a problem? I don't know how to tell if it is a world class or the other type, I need some guidance as to tell the diffrence.
what is the easiest way to determine which is the w/c or not? also
I have some of the Mazda trans from an F150, I am thinking about putting it in my 46
half ton. with an 8ba can a person use the automatic trans engine to bell adapter
and maybe make a pilot bearing extension to compensate for the adapter distance?
these mazda trans have a good low gear for a pickup with the advantage of the 5th overdive. sounds to me like a good combination, I want some input as to the feasibility.
Thanks,
fordestes
Fordestes is offline   Reply With Quote
Old 12-06-2014, 12:12 PM   #7
gearhead1952
gearhead1952's Avatar
My 96 ranger takes ATF also.
gearhead1952 is offline   Reply With Quote
Old 12-06-2014, 02:00 PM   #8
Barry-ct
Barry-ct's Avatar
Use the Mercon V in it. Yes, it is reverse compatible with all the earlier Mercon /Dextron formulas. I went thru all these changes working at the dealership level in parts, so it is the correct fluid. If you have an owners manual with the Ranger , all your fluids and capacities are listed in it.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 12-06-2014, 11:45 PM   #9
Brendan
Brendan's Avatar
thanks for your help. I needed to change the oil in my trans, it just seemed weird to me to put atf in a manual trans
Old 12-07-2014, 09:24 AM   #10
john in illinois
Brendan,I thought the same thing,but I was told the transmission was designed for thin oil and thick oil would not flow into bearings.
Also all large farm tractors use thin ATF type hydraulic oil in the transmission and rear end. That always amazed me when I was farming.
John
Old 12-07-2014, 10:11 AM   #11
Mike51Merc
Mike51Merc's Avatar
As far as I know, the ATF is important because the newer transmissions have carbon fiber sliders on the synchronizers and regular oils will delaminate them.
Mike51Merc is offline   Reply With Quote
Old 12-07-2014, 10:30 AM   #12
Brendan
Brendan's Avatar
I don't think the oil in my trans was ever changed it came out very dirty. this little truck is my bread and butter so I need to take care of it. the owners manual said to put in 3 qts of mercon. it is happy and I think it shifts easier
