06-12-2016, 01:22 PM | #1 |
Stuck Pitman Arm
Any tricks on getting a pitman arm off? I am trying to replace my pitman arm on my 50 F1 due to egg shaped ball. Broke 2 pullers trying to get it off and haven't budged it yet. Any ideas????
06-12-2016, 01:30 PM | #2 |
Re: Stuck Pitman Arm
Support one side with a BIG hammer, and whack the opposite side hard with a hammer only a bit smaller. Then try a puller. If it wont pop right off, use heat around the outside.
06-12-2016, 01:48 PM | #3 |
Did you break a regular puller or a pitman arm puller? A good pitman arm puller like a snapon will get it off. It's a tapper and splines.
06-12-2016, 01:58 PM | #4 |
they were regular pullers
06-12-2016, 02:00 PM | #5 |
A good quality pitman arm puller is one piece that slips around the pitman and a screw to press against the sector with a center point.
06-12-2016, 02:10 PM | #6 |
Use an impact wrench too. http://www.tooltopia.com/otc-tools-8...FYqPfgodjZYNjg |
06-12-2016, 02:17 PM | #7 |
autozone or o'reilly's nearby??....they rent the tools and probably have that for rent....good luck....Mike
06-12-2016, 10:59 PM | #8 |
I have a 3ft crowbar that has worked for me. Prying between the frame and back of pitman arm. Also use a propane torch to heat up and break the rust bond.
06-13-2016, 07:25 AM | #9 |
Heat it a bit with a propane torch.
