Old 09-21-2011, 06:41 AM   #1
ventilo
Default Convertig '34 4-cylinder to V8 - what does it take?
I'm considering aquiring a '34 "Rheinland" convertible with the model B powertrain. What does it take to convert this car to a V8?
I've already got a complete French flathead, but obviously would need to find a suitable transmission and a V8 radiator. What else needs to be swapped?
ventilo is offline   Reply With Quote
Old 09-21-2011, 08:06 AM   #2
Kerk
Default Re: Convertig '34 4-cylinder to V8 - what does it take?
i THINK THE DRIVE SHAFT & TORQUE TUBE ARE DIFFERENT LENGTHS ! SORRY FOR CAPS. KC
Kerk is offline   Reply With Quote
Old 09-21-2011, 09:21 AM   #3
ventilo
Is it straightforward to lengthen or shorten the shaft?
Or should I try to find the correct shaft & tube instead?
Old 09-21-2011, 09:31 AM   #4
Bruce Lancaster
V8 tube should be pretty easy to find, here at least!
New main wiring harness...some sort of adaptor like the C-shaped Ford ones to go from the engine mounting pads to the wider V-8 span, truck pumps would be the normal USA choice, think the French engines use something a bit different.
V8 choke and throttle parts...
With the side mounted distributor and the long pumps of the later engine you will have to do some engineering to get fan and everything into place behind the '34 radiator. A '48 and back type engine has much shorter stack of front accessories and is easier to fit with similar to stock fan arrangement...
Bruce Lancaster is offline   Reply With Quote
Old 09-21-2011, 11:20 AM   #5
Charlie Stephens
It is my observation that in this country at least a well restored 4 cylinder will attract as much attention as a V8 because everyone "restored" what few cars existed as V8's. A well restored 4 cylinder is very unusual.
Charlie Stephens
Old 09-21-2011, 11:26 AM   #6
PeteVS
PeteVS's Avatar
There was an informative thread a while ago about the misadventures of swapping between V8 and 4 banger in a '33-'34 pickup...
https://www.fordbarn.com/forum/showthread.php?t=3123
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 09-21-2011, 10:28 PM   #7
DavidG
DavidG's Avatar
Boo!!!!! Hiss!!!!!
Old 09-22-2011, 12:15 AM   #8
Kirby1374
Kirby1374's Avatar
Yes but he got it all together and it turned out awesome.
Kirby1374 is offline   Reply With Quote
Old 09-22-2011, 12:57 AM   #9
barryfromvictoria
thats a rare car with the 4 cyl.
barryfromvictoria is offline   Reply With Quote
Old 09-22-2011, 04:12 AM   #10
ventilo
I'll test drive the Deutsch bodied Rheinland next Tuesday. If she turns out to be fine I might think about leaving the Model B banger in there.
Fan and distributor clearance with the French Flathead is an issue, I ended up using an electric pusher fan in my '37 Cologne built V8.
