adding electric fuel pump
1950 Ford. We are planning to add an electric fuel pump - will be putting in line just in front of the rear leaf spring on the frame rail. Questions: The fuel line is currently secured to the frame rail using adel clamps, so we expect to be removing a few of those so we can get access to the line to spin a tube cutter abound the line. But should I be concerned about the gas in the line from the tank - Should I siphon out the take before attempting this? I need to cut the tubbing, then flare the ends .
