03-20-2012, 11:27 AM | #1 |
1936 1.5 ton truck key and switch ?
I'm tying to figure out what these two things are and what they do. I have the keys for the key hole. This truck has been sitting since about 1972. The engine oil is full and clean and I took all of the spark pugs out and the engine turns over with the push button starter in the floor. I took the carberator apart and cleaned it also and I'm ready to see if the spark plugs will fire but not to sure what turns on the power to the system.
Thanks Mike |
03-20-2012, 11:30 AM | #2 |
Re: 1936 1.5 ton truck key and switch ?
Picture of the engine that's in the truck.
Mike |
03-20-2012, 11:31 AM | #3 |
With the ignition switch in the "OFF" position, your engine will turn over but will not fire the engine. With the ignition switch in the "ON" position your engine will turn over and deliver spark to the plugs.
03-20-2012, 11:34 AM | #4 |
03-20-2012, 11:36 AM | #5 |
The lock locks both the switch beside it and the steering shaft, the switch lever controls ignition. Starter would have been a foot pedal stock, many of this vintage have been converted to a '37-48 pushbutton on dash/solenoid for starter.
03-21-2012, 07:18 PM | #6 |
Thanks Mike |
03-21-2012, 08:27 PM | #7 |
I would say that you probably have to clean, adjust the points. You may want to take a look at the spark plug wires too.
Red |
03-21-2012, 09:25 PM | #8 |
What's the best way to get to the points I have never had one of these apart.
I'm sure I can get it apart but i do not won't to get anything out of time. Thanks for the help. Mike |
03-21-2012, 09:33 PM | #9 |
If the engine oil is full and "clean" in an engine that has been sitting for a long time i would drain it before starting the engine---even if it is into a clean pan to be reused ---the reason is sludge, when old oil sits for a long time all the "dirt" in suspension falls to the bottom and makes a layer of sludge on the bottom of the pan, many times covering the oil pickup in a 2-3 inch layer ---take out the oil drain plug --if you have to poke a hole to get it to drain you know that you definitely have to drop the pan before trying to start the engine --in any event poke around with a wire and see what comes out ---the stuff laying in the bottom of the pan is first to the bearings.
Before you go out for a drive check the oil in the steering gear --and the trans and rear ---it's no fun when something siezes up on the first drive just for lack of oil. remove dist, take off coil ---then If you mark where the timing screw is(has curved rectangular washer with dashes on side of dist),remove it, take the top off the vacuum brake (big hex with screw in center), remove spring and plunger(piston with leather in center rubbing on disc) --then the insides with rotor, advance, and points can be pushed out ---sometimes heating the alum housing some can loosen a corroded one ---then points can be removed and cleaned ---if the springs arn't broken and there is enough material left on the contacts-- I like the results of using a diamond knife sharpening "stone" --a small penknife size one for dressing points ---but I have used files, knife blade scraping, sandpaper even stones and concrete to clean points. put it back together--don't forget to lube the cam, then with the coil installed (puts pressure on the point plate to help seat it to prevent point gap changing after you set it) set the points gap (to do a perfect job there are fixtures to set them and the timing -and more cleaning and lubing--but to just getting it running making spark should work The vacuum brake is sort of a vacuum advance, the tighter the spring is screwed down the LESS vacuum advance you have, the disc the piston rides on should be smooth --smoother the better , if it is rusty it will eat the leather button on the end of the piston. Last edited by Kurt in NJ; 03-21-2012 at 09:55 PM. |
03-21-2012, 09:55 PM | #10 |
Will do.
Mike |
03-22-2012, 10:42 AM | #11 |
Thanks for the help Kurt. I cleaned the points and while i have this opened up i was going to check the gap on the points.
Does anyone know what the point gap should be on this engine? Thanks Mike. |
03-22-2012, 10:47 AM | #12 |
From your picture above, your distributor is 1933-36 type, .012-014...
Cylinder head is '46-8, meaning you have a later 24 stud engine, not necessarily the '46-8 matching the head but probably that. Practically everything flathead exchanges into some or all other applications one way or another, and on a vehicle with many years of parts swapping behind it you will need to ID each thing you work on... |
03-22-2012, 01:11 PM | #13 |
I set the gap at .014 and put it back together and the plugs spark like the 4th of July.
I put about 3oz of gas down the carburetor to see if the motor would just hit and after almost one rotation it started up and idled until it ran out of gas. I wasn't ready for it to start so it scared me and also a unbelievable happy feeling also. To The people that help me I can't say enough for your help. Wow!! Mike |
03-22-2012, 01:33 PM | #14 |
That is a great feeling! I would set the thing up with a small temporary gas tank while debugging and tuning, and drop out the gas tank for a thorough cleanup.
I would have some spare points handy...these things have a long steel spring, and in my experience the spring has some tendency to break on distributors that have been sitting for a long time. |
03-28-2012, 08:57 PM | #15 |
For what its worth, I have a similar coil in my BB. The original one in the truck was at least 50 years old,would work well for about 5 minutes then break down. I replaced it with a NOS one that lasted about 30 minutes before it heated up and the spark would start to crap out. I got Skip in FLA to rebuild the NOS one and the truck runs great ( at least for as far as I've gone so far but that hasn't been that far). At least the,spark doesn't break done anymore.
