12-19-2015, 08:37 PM | #1 |
Odd issue with my horn
Had some troubles with my horn a while back and thought I had things squared away. Lately it started acting up again and it took me a bit to figure it out. Ended up being a grounding problem between the two bolts that attach the horn body to the bracket that mounts onto the headlight bar. Got lucky and noticed a slight wiggle in that area so I grabbed a 7/16" wrench and gave the two bolts a tug. Now I don't think my horn has ever sounded so good. Sometimes it really is the simple things.
Dave / Lincoln Nebraska |
12-19-2015, 10:15 PM | #2 |
Re: Odd issue with my horn
That's interesting. The horn gets it ground from a wire. I wouldn't think it matters wether it was bolted to the frame or not?? Anyone else have thoughts on this?
12-19-2015, 10:15 PM | #3 |
The horn doesn't use any grounding other than the horn button, if you have an original horn.
Some of the aftermarket horns may use a horn body ground. |
12-20-2015, 12:09 AM | #4 |
The important thing is you got it working!
12-20-2015, 02:16 AM | #5 |
If you look at the wiring diagram, the hot is connected to the horn continuously. The grd goes from the horn button connection down a wire thru the light switch at the bottom of the steering column and on thru a wire to the horn. So there are two wires, one hot,one the ground. So why does the the horn itself have to be grounded?
12-20-2015, 05:08 AM | #6 | |
I put it on quite some time ago when I was chasing other gremlins in the system. I could probably take it off now. But..... it is working like a champ so I think I will leave well enough alone.
12-20-2015, 07:48 AM | #7 |
Always REMEMBER - The Model A was designed and built with the KISS principal. jiml...
12-20-2015, 10:38 AM | #8 | |
Bill W.
12-20-2015, 11:18 AM | #9 |
Keep It Simple Stupid
12-20-2015, 11:35 AM | #10 |
So the horn should be isolated from the frame. Is that correct?
12-20-2015, 12:43 PM | #11 | |
Pardon me for all this babbling, but Cindy jist sent me 96 JET-FUEL K-CUPS for my magic coffee machine & I'm WIRED!! Afraid to drive, I might git a DUI-J-F citation bILL w.
12-21-2015, 07:26 PM | #12 |
good info
