05-18-2023, 08:05 PM | #1 |
Flathead H226 Overdrive
Hi All,
Does anyone know if any of the 6 cylinder 49-51 cars came with or utilized overdrive transmissions? I need something that will allow me to drive my Shoebox on the highway? Another option I have been thinking is to install a 9" rear with 308's but wondering if i would lose all of my bottom end. Thanks, Steve |
05-18-2023, 09:00 PM | #2 |
Re: Flathead H226 Overdrive
Yes, the sixes used the same OD as used on the V8's...
05-18-2023, 09:12 PM | #3 |
My current transmission has a Hurst floor shift. I know the original car had column shift, looks as though the solenoid would would be in the way of the floor shifter and linkage. Any thoughts on that...?
Thanks, Steve |
05-18-2023, 09:24 PM | #4 |
I can't help you with that unique scenario. In my case, I removed the transmission and OD from a 6-cylinder engine and installed it in an original '49 V8 with column shift...
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 05-18-2023 at 10:41 PM. |
05-18-2023, 10:08 PM | #5 |
my 50 ford has a6cyl with 3 speed pverdrive run down the hwy just great
05-19-2023, 06:04 AM | #6 |
05-19-2023, 06:49 AM | #7 |
My 1st car was a 1950 six cylinder with overdrive. It was a GR8 car & could run 70 mph all day. I remember the Fenton shifter, but didn't have the $$$ for one after rebuilding the engine. That 6 by the way, beat a few V8s.
05-19-2023, 11:25 AM | #8 |
The convertibles had a solenoid adapter the relocated the solenoid under the transmission with a rocker set up. The X frame would not accommodate a standard R10 set up so the adapter made it possible. They aren't easy to find but they are out there.
05-20-2023, 07:44 AM | #9 |
Was not aware of that, thank you!
