09-05-2016, 02:56 PM | #41 | |
Re: Tires slowly leaking
Anybody ever have to patch a tire or tube after somebody put some of that green slime stuff in it and it didn't work ? Give it a try, if it don't work your only out a few oz's of anti-freeze and 10 min. of your time |
09-05-2016, 04:07 PM | #42 |
09-05-2016, 04:17 PM | #43 | |
09-05-2016, 04:49 PM | #44 |
09-05-2016, 05:07 PM | #45 |
Gee I'm amazed how well my car tires actually hold air --better than I would have suspected with tubed tires.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
09-05-2016, 05:22 PM | #46 |
A very common misconception.
09-05-2016, 08:01 PM | #47 |
I can't see using calcium it tractor tires as being illegal, they use tons of it on the roads in winter all over the country, not to mention in other parts of the world as well.
09-06-2016, 06:37 AM | #48 |
My tires never leaked air with the rubber stems but after buying new tubes with the metal stems they go down about 5 lbs. in 2 weeks.
09-06-2016, 08:15 AM | #49 |
Barry, are the stems vulcanized in the tube or the original style bolt in metal stem?
09-06-2016, 10:33 AM | #50 | |
Plenty of posts re this subject and it puzzles me as well. Tubes are metal stem some older than others. Same issue ?? Inflate up to 35 and within a month all 4 are down to 28 or so. Never any lower than 25 yet never stay at 35. All 4 same thing. One of life's little mysteries I guess.
Dave A Jamieson Portland, ON Canada 1928 Tudor |
09-06-2016, 12:36 PM | #51 |
09-06-2016, 02:59 PM | #52 |
The tubes came complete with the metal stems attached, they probly were vulcanized, I checked the pressure yesterday after 2 weeks and they were all down somewhere between 10 and 15 lbs. I still like the metal stems and the tubes looked to be well made, just have to check them more often I guess.
09-06-2016, 04:47 PM | #53 |
Slime is garbage! I've put it in small tractor tires and they held air for maybe a a month or so, then they were just as flat. Fix it right! Get a new tube and replace the old one. I don't was to start another war of words, But the ones I get from TSC have been all right. Maybe someone has different experiences. Also, I bought four new tubes from Smith and Jones several years ago (I don't recall what brand they are) but i've only added air once.
Terry |
09-06-2016, 04:48 PM | #54 | |
09-06-2016, 04:52 PM | #55 |
Of the four tires on the ground with late 80's air in them, only one loses 3-4 lbs annually. Some are metal stem and some rubber stem (It's a driver).
Paul in CT |
09-06-2016, 05:55 PM | #56 |
I agree with Terry about the slime being junk. It didn't work in my bike tire either, but sure made a mess. Some tire stores charge extra if they have to deal with the mess it makes.
09-06-2016, 10:08 PM | #57 |
I use slime on lawnmower, wheelbarrow, trailer, etc tires. Works great for many years. Use some common sense, if you have a nailhole, it won't work. If you have a slow rim to tire bead leak slime will work well. After some time (years) it dries in the tire and is no longer slime but more of a latex.
09-09-2016, 10:50 AM | #58 |
Ideal gas law!!
We have deflation problems in New England too Tommy- |
