05-08-2015, 06:53 PM | #1 |
Hot Brakes
1929 Sport Coupe. On the left front brake I put a new drum/hub (assembled and turned by vendor). It went on very right riding the brake shoes (pretty new themselves). The shoes were adjusted out as far as they could go but are still riding.
Took it for test run and drum/hub is too hot to touch. Dis-assembled and using a wire wheel ground down the obvious riding spots on the shoes. Re-assembled and test drove again. It is better but still gets too hot to touch. 1. When driving it does NOT pull to the left. 2. No noise when driving. 3. Front wheel bearings are less than 1000 miles old. Probably less than 500 (just put a speedo in). 4. Jacked up the front end and both front wheels have the same "drag" when I spin them. Ideas?
John from Kapowsin T&A Guy Last edited by jwaldrich; 05-08-2015 at 07:20 PM. |
05-08-2015, 07:17 PM | #2 |
Re: Hot Brakes
Were the shoes fitted to the drums? There should be no dragging, dragging makes heat.
05-08-2015, 07:19 PM | #3 |
Re: Hot Brakes
No they were not. Should there be NO contact between shoes and drums prior to brake actuation?
John from Kapowsin T&A Guy |
05-08-2015, 07:21 PM | #4 | |
Re: Hot Brakes
These are dragging like brakes from my youth. Bad?
05-08-2015, 07:33 PM | #5 | |
Re: Hot Brakes
You have the brake adjusting wedge backed all the way out?
http://www.abarnyard.com/ |
05-08-2015, 08:23 PM | #6 | |
Re: Hot Brakes
05-08-2015, 09:03 PM | #7 |
Re: Hot Brakes
If the adjuster is sticking out of the backing plate considerably more than all the others then there is an assembly issue. If you disconnect the brake rod will it still have drag?
05-09-2015, 06:42 AM | #8 |
Re: Hot Brakes
I hope the front wheel bearings aren't too tight. Just the slightest snug to get rid of hub end play is what's needed. I saw a hub broken by tightly torqued front wheel bearings. Of course this would have also caused considerable heat before it broke.
05-09-2015, 08:10 AM | #9 |
Re: Hot Brakes
The front wheel bearings were taken up snug and then backed off to align the cotter key. They were not "torqued".
05-09-2015, 08:38 AM | #10 |
Re: Hot Brakes
To have great effective brakes you need to have maximum initial shoe contact to the drum with the shoes mated and arced to the drum and centered on the backing plate
I would purchase one if the shoe centering gauges from Snyders or Brattons and first remove the front brake shoes and take the shoes themselves and using about a .005 feeler gauge see how they fit the drum . Hold them firmly into the drum while using the feeler gauge . That will give you a guide if the fit and shape of the linings to the drum . As part of my brake work I always arc and fit each shoe . If you don't have a shoe arc available anywhere you will just have to figure out your own method . Don't grind the crap out if them . Next step is to make sure they are centered correctly using the gauge Contact should be fairly even all the way around the shoe . Yes there will be a break in period and a couple if adjustments at the wedges once the rods are properly set for drag evenly at all wheels . You do not want constant full drag without brakes applied . As Marco said a little high spot on a new job may be normal but will quickly disappear . Wish you were closer . Brakes are one of my known specialties . Everyone thinks brakes are easy and they are not , but well restored and adjusted properly with all things right can stop in a dime Use an infrared heat detector to check you drum temps When broke in and properly done I usually see them within 5-10 degrees of one another Larry Shepard Last edited by larrys40; 05-09-2015 at 09:53 AM. |
05-09-2015, 09:18 AM | #11 |
Re: Hot Brakes
05-09-2015, 09:34 AM | #12 | |
Re: Hot Brakes
This scenario doesn't QUITE COMPUTE, to me & you seem to know what you're doing. Especially when there's NO pulling or abnormal brake action. Bill W.
05-09-2015, 04:28 PM | #13 |
Re: Hot Brakes
It is my OP that if you build up the tracks to stock dimensions, use shoes that the roller and adjuster pin holes are in good shape, new pins and rollers, arc the shoes to the drums, centering does nothing.
As soon as you adjust the brakes to your drums the adjuster pins that anchor the shoes are locked so every time you press the brake pedal it's only pushing the shoe out from from the activator end. Plus the idea of bending the track up or down, I don't get that! You have a nice straight track, then you bend it? Did centering tools even come out in the Model A era or was that a V8 thing, which used different brakes. |
05-10-2015, 12:01 PM | #14 | |
Re: Hot Brakes
When I apply the brakes they do pull to the left but that is little more than a brake adjustment to the right side since the wedge is backed off all the way on the left. That did seem a little weird to me. I can understand backing the wedge off but all the way? but then turn it back in not at all? Before I take these shoes in to have them arced to the drums I'll have exhausted every suggestion here and the one that makes sense to me now is the wheel bearings. I'll snug them up and try again as well as check for correct assembly of the backing plate and adjusting wedge.
05-10-2015, 12:12 PM | #15 |
Re: Hot Brakes
Yes they had centering tools since the first Model A's.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
05-18-2015, 09:47 PM | #16 |
Re: Hot Brakes
New development:
Now have NEW cast iron drums on both front spindles. Brake adjustment is backed off all the way. Test ran ruturned both front drums over heated. When I re-install the drum on the right hand side, the minute I tightened the axle nut only finger tight I got drag. Me thinks I have bearing issues...
05-18-2015, 10:27 PM | #17 |
Re: Hot Brakes
If it turns easy before you finish tightening the wheel bearing ---then when the wheel bearing is adjusted properly the drum binds on the shoes you have a centering problem
05-18-2015, 11:01 PM | #18 |
Re: Hot Brakes
Could the Brake Shoe be rubbing the vertical part of the Drum? Like to shoes are to wide, or not seated correctly, causing the shoe to rub on the side of the drum, not the braking surface.
My thought is to change something to see if the problem stays or changes. Maybe try a different set of drum if available? Just a thought. |
05-19-2015, 07:53 AM | #19 |
Re: Hot Brakes
Just went through Cast Iron drums on front of mine. One thing leads to another.
A great guy in our club did the work and has done countless brakes. 1. Dragging drum a) shoes centered b) Have you arched the shoes to fit drum 2. Were new drums turned? New cast iron drums need to be turned down around .0020 to fit properly they are thicker than org. steel drums. 3. Worn tracks I was amazed how many steps it took to get them right. 8 hrs later I have great properly adjusted brakes. I helped... (grunt work) and realized that is sure helps to have a fully equipped machine shop to deal with issues on these mechanical systems. ( had to build up the tracks (welding) then machine them back to specs.) I use a temp. gun to check my brakes when touring. Rears warm but not hot. Fronts are cool or slightly warm. (60 percent braking on rear) It will also tell you which brake is doing the most work or is too tight. Last edited by barkleydave; 05-19-2015 at 07:58 AM. |
05-19-2015, 08:02 AM | #20 | |
Re: Hot Brakes
